Old 05-19-2016, 12:08 PM   #11
Chassis: International S3800
Originally Posted by Robin97396 View Post
Is it possible there is something wrong if the fan is making that much noise? I can't hear my fan at all.
depends on the fan.. if you have an air-fan-clutch you get Much more fan noise because your fan is either fully engaged or fully disengaged.. so when it comes on its typically a big roar similar to that you hear when semi truck fan comes on.. most of the air fans ive seen are many-blade plastic fan wheels which move alot of air but also are noisy..
if you have an old school thermal fan clutch(its completely mechanical) then your fan gradually speeds up and slows down as the air temperature from your radiator increases or decreases. so you may almost never be running your fan at full speed unless you are under high temperature / heavy load...
thermal fan clutches fail quite a bit more than air fan clutches do so they went to air.. also the fans on the thermal clutch fans ive seen are mainly smaller number of blades and metal so they are typically a lower pitched sound when they operate.. though can still roar pretty good..
P.S EDIT: I should add that mechanical thermal fan clutches are typically MUCH cheaper to replace than air actuated fan clutches.. AND they CAN be adjusted...
Old 05-19-2016, 01:10 PM   #12
Originally Posted by Templar View Post
With the rear bedroom done the noise is very low.
I look at it this way - with RE when you're driving you're up front and the engine is in the back... When you're sleeping in a back bedroom, if there's any engine noise it's probably going to be from a generator which is going to be somewhere forward of the bedroom.
jake_blue is offline   Reply With Quote
Old 05-19-2016, 03:43 PM   #13
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
On the 6 hour trip to SE Indiana, my fan never comes on until I'm climbing the long steep hill into Haspin Acres offroad park. You might not have ever heard your fan because you've never gotten the engine warm enough, going slow enough, to kick it on.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 05-19-2016, 04:58 PM   #14
In just about any kind of front end collision i would want the FE Bus. FE Bus will take a lot rougher road than a low sitting RE.
Old 05-19-2016, 05:33 PM   #15
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I know the driveway I have to go down to store my bus sure is rough. Lots of sugarsand and slightly uphill and very narrow with a 90 degree left into it.
But yeah like many I set out to get a RE bus but am now super stoked I got FE.
Roll Your Own Build Thread
Old 05-19-2016, 06:00 PM   #16
Chassis: Genesis
For whatever reason, I have yet to see a DT466 mechanical in rear engine configuration. I'm quite happy with the FE so far, though.
Timelord is offline   Reply With Quote
Old 05-19-2016, 06:09 PM   #17
Robin97396's Avatar
There's definitely advantages to both. I'd really rather be going cross country in a RE with air ride and all that space. For messing around in the mountains like I do this FE seems better for me, and yes I do climb hills and heat this baby up. The length of a RE is what stops me, or any other 40' bus for that matter. My bumper digs gravel on my own driveway as you drive through the creek and this is only 26'.
As for any 40' buses that might visit on our cross country skoolie camping plan, there are areas in the lower orchard with plenty or room to turn around (if it hasn't been raining).
