Originally Posted by efgjr
Hello All, Officially brought bus home recently. It was 101 deg out and inside you could touch the ceiling and not feel any heat transfer. Is it recommended to removes all sheetmetal and start over or are there good methods of adding thin ins layer and decorative cover? Also my bus is a 97 3800 with T444E. Are these good buses its got 191000 ? thanks
Pull the sheet metal that is the ceiling. The fiberglass batting that's insulation is crap, and can be full of mold and rot. Because do you *really* want to be breathing this crap in-
I've got an 03 Amtran RE (Int'l 3000RE) with the same plant, 70k less on the odo, but it runs strong. If you hadn't gotten new fluids when you picked it up, at the very least do an oil analysis.
Blackstone Labs do a cheap and accurate test kit by mail.
