05-03-2017, 03:06 PM
#21
Ok, the one in your pic is a Bluebird. Its on an international chassis.
Low headroom model.
Find out what transmission, engine, and rear end its got.
Internationals are great, and if its a mechanical 466 you definitely did good.
If its a 6.9 with a 6.50 rear and 545 tranny, I'd try to move on.
How old are the tires?
05-03-2017, 03:09 PM
#22
Low headroom model.
I believe it's a 4 speed trans. And since it's a 1992 it doesn't have the T444e so I did research and it showed that them 1992 models had a IHC 7.3 engine
Sent from my Alcatel_4060A using Tapatalk
#23
Low headroom model.
And I think the tires been on the bus for years
05-03-2017, 03:31 PM
#24
That's not a lot of engine for a full size bus.
Find out what the rear axle ratio is, that will tell you if its a 45 mph bus or a 55 mph bus.
05-03-2017, 03:32 PM
#25
Ok. My bus bus 102 it does 70 mph
05-03-2017, 03:36 PM
#26
A diesel shop shouldn't have sold you a bus that had been overheated numerous times and also had a bad oil leak. They had to know you wouldn't make it home with 102.
I'd definitely try to get them to switch up for 101 unless it has similar problems. That overheated engine isn't what you want.
From what I understand you're only out $200 so far? I'd take the bus back to the shop and park it right in their way at the shop. Try to get 101, and if they won't do that back out of the deal on 102 completely and give it back to them.
This isn't starting well.
Robin
Nobody's Business
05-03-2017, 03:37 PM
#27
But I know nothing about bus 102, how am I supposed to tell you anything?
05-03-2017, 03:38 PM
#28
Well said, sir.
05-03-2017, 03:39 PM
#29
Thanks. I ask about 101 and only problem it has is cranking but it runs. 102 runs but it has them problems. What sad tho. 102 was the best running bus I seen
05-03-2017, 03:40 PM
#30
😂. I was just saying basically. I was talking about them questions you told me to ask so you could try to help with the information about it. When I find out I'll keep you posted
05-03-2017, 03:45 PM
#31
Ok, no worries man. You know how these internets are. Conversations get a lil confusing sometimes!
Keep us posted. We love helping folks find that "right" bus.
05-03-2017, 03:46 PM
#32
I really appreciate it. 👍
