Old 09-13-2016, 08:54 PM   #11
Skipoffools's Avatar
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
I also picked up some redwood siding and vinyl house windows off craigslist. Removed the rear and driver heater. I plan on installing the rear heater below and redirecting hoses so we can at the least have defrost. Also in the process of downsizing the rats nest of an electrical panel.
Pictures later, my internet is slow.
Skipoffools is offline   Reply With Quote
Old 09-13-2016, 08:58 PM   #12
GreyCoyote's Avatar
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
That little 'un in the last frame is just as cute as a bug. Good to see you have lots of "help"!
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
GreyCoyote is offline   Reply With Quote
Old 09-13-2016, 08:59 PM   #13
Engine: DTA360
Rated Cap: 63
No we got 7 double pane fancy shmancy low e vinyl house windows. Not sure exactly how they will be installed yet but, I figure I'll add some framing and sheet the exterior with plywood, tyvek, and redwood lap siding. Then just case the windows like a house.
Old 09-13-2016, 09:01 PM   #14
Engine: DTA360
Rated Cap: 63
Yeah she like to help, even after multiple metal shaving splinters. Just can't keep shoes on that girl.
Old 09-13-2016, 09:09 PM   #15
Engine: DTA360
Rated Cap: 63
Oh yeah and anyone who has experience, ideas, or suggestions about skinning a bus with wood. I'm all ears.
Old 09-13-2016, 09:30 PM   #16
Coachwork: IC
Chassis: CE300
Rated Cap: 32
nice name!
Roll Your Own Build Thread
Old 09-13-2016, 09:55 PM   #17
24 inches...???...that's a lot of roof raise!
Old 09-14-2016, 08:37 PM   #18
I'm eager to see what comes of the wood/panel siding, to be honest. I've been thinking of doing the same for mine when I eventually get it.
For the roof-raise, did you go to somewhere special?
2 feet is a lot of extra headroom. What are you planning to do with all that extra space?
SpecialAgentAce is offline   Reply With Quote
Old 09-15-2016, 05:29 AM   #19
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
skin it with metal first, that should keep it rigid and water tight. then put your wood on. 18 g should work fine
my build pics
Old 09-15-2016, 01:37 PM   #20
Rated Cap: Your mom +1
what he said... you could probably even get away with 20 if the wood sheathing you're going to use is thick...
