Old 12-03-2018, 07:49 PM   #1
DMCGARIGAL's Avatar
The wait is over!
Still cant believe I am writing my introduction on skoolie.net telling everyone that I am the proud new over of a 1996 Thomas RE. 3 years ago I joined this site and scrolled through the forums, drooling over the builds thinking it would be nice. Well last week I bit the bullet, bid on a bus on a whim with some encouragement from my fiancÚ to "just go for it" and we won. I anticipate doing a build thread with tons of photos, because everyone loves the photos so don't worry.
I am a trained diesel mechanic so everything under the bus doesn't worry me. but I have TONS of questions about the interior build.
the number one question I have, that I have yet to see in any thread, and ill start with this is:
What type of hardware is used to secure the wooden frames to the "skin" of the bus? For example, rip out the old insulation in the walls and ceiling, add better insulation and reinstall wooden walls and ceiling, what type of fastener (i.e. screw, self taping screw, glue, Velcro (lol)) is then used to hold the wood to the ribs of the ceiling/walls?
Literally the only thing (as of right now) that keeps me up at night when dreaming of my build.
DMCGARIGAL is offline   Reply With Quote
Old 12-03-2018, 07:52 PM   #2
DMCGARIGAL's Avatar
oh one other thing, I'm out of southern California, Orange county area, does anyone know of any skoolie community in the area where people meet to work on their buses together here?
Old 12-03-2018, 08:00 PM   #3
Welcome aboard. Don't let that keep you up at night when there's thousands of other things to keep you up at night! We attached 5mm underlayment (luan plywood, basically) to the ribs with self tappers, then attached beadboard to the underlayment with a brad nailer and adhesive.
Old 12-03-2018, 10:45 PM   #4
plfking's Avatar
Rated Cap: 34
I've used several different things.....some 2 x 4s are attached with joist hangers (u clips), or bolted through ribs, or pre-drilled and screwed (I've found it almost impossible to run a 2" self-tapper through the wood and into a rib without pre-drilling).
And I haven't ever seen this mentioned, but I've attached a lot of my framework to the "backside" of the ribs....not the frontside or "face". My worst-case stress on the framework (short of a rollover or head-on collision) would be locking up the brakes, so I've put my framework in a position that during extreme braking, the wood will be pushed against the ribs, and not pulling away from them and putting all the stress on the fasteners. Not sure if this will actually help in such a situation (and don't want to find out), but it can't hurt.
The bottoms of my frames are screwed through the plywood floor AND the metal floor, for hopefully some additional strength.
Don
The Busted Flush
Old 12-03-2018, 11:25 PM   #5
DMCGARIGAL's Avatar
Thanks for the input!
Old 12-04-2018, 09:02 AM   #6
Year: 1994
Definitely concur with the above ideas.
I used cabinet screws for some to prevent splitting wood. Most of top attached with a variety of metal brackets. Flooring was straightforward after I got over putting holes in my freshly patched floor.
Jameson is offline   Reply With Quote
Old 12-04-2018, 09:04 AM   #7
DMCGARIGAL's Avatar
Awesome, thanks for the photos!
Old 12-04-2018, 12:45 PM   #8
So glad you bought your bus! Where do you live?
I'm still lurking and close to pulling the trigger on a bus.
BlueFish aka Todd
Seeking a Crown, Thomas, International, Blue Bird bus with DT466, Cummins 8.3, Allison trans, high roof, air brakes, and A/C.
BlueFish is offline   Reply With Quote
Old 12-04-2018, 05:00 PM   #9
DMCGARIGAL's Avatar
Long Beach, pulling the trigger was terrifying, yet liberating. I still have days where I’m like “what the eff did I do?!” And then other days I spend all day researching and dreaming of ideas for the inside.
Old 12-05-2018, 11:56 AM   #10
Rivetboy's Avatar
hi congrats! So where are you parking it?
Rivetboy is offline   Reply With Quote
