We found a shipper who drove the bus up from MD for a reasonable cost, because there was no way to get plates or temp tags for it. 3 hours at NJ DMV and 2 Hours with MD MVD with no luck.
Things I have learned so far:
1.) There is a button in the back of the bus that needs to be pressed once the bus is shut off, it is a safety check for left behind children. 2 hours of buzzing and a couple of phone calls, got it figured out.
2.) The button for the door release(air operated) does not work when the bus is shut off. You can use the emergency release lever to exit the bus, I just used the side emergency door.
3.) The neighbors will ask what the heck are you doing, glad his wife is a bus driver and he was cool about the situation.
These little things had me laughing for a couple of hours trying to figure them out.
