Old 09-04-2017, 11:09 PM   #1
What's this bus worth?
I came across a group of Thomas busses for sale. Here's a couple pics of the one I'm interested in. What do you think it's worth? I am hesitant about buying a bus yet because I have word that there'll be a windfall of busses on the market here soon. Opinions?
Sent from my SM-J700T1 using Tapatalk
cwol97401 is offline   Reply With Quote
Old 09-04-2017, 11:14 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Caterpillar C7 EFC7210
5800 hours
What state? Rust?
Old 09-04-2017, 11:32 PM   #3
Oregon no rust visible. There's no salt on the roads here and it's got markings hinting to the valley.
Old 09-04-2017, 11:40 PM   #4
The vintage and shift quadrant suggests you have a MD3060 5-speed OD transmission.
At a guess the way in which the bus is spe'c'ed it most likely is not a 250 HP engine and more likely in the 210-235 HP range.
It will not be a powerhouse on the hills but it should cruise very easily at 60 MPH depending upon the gearing in the rear end. I came across one that had a C7 250 HP engine with really short legged rear gears. It would take off from a stop like a scared rabbit but it tached out at 57 MPH.
Since it is from OR it most probably does not have any rust.
I would guess the asking price is going to be in the $5K-$7.5K range with a reasonable sale price in the $3.5K-$4.5K range.
Old 09-05-2017, 09:37 AM   #5
Traveling
Rated Cap: '00
2005 - electronic, not too many emissions yet
2000 Series trans, says sticker, so doubtful md3060
Caterpillar C7 EFC7210 would be: Electronic Fuel C7 210 HP ...guessing.
usual disclaimers
tire condition?
Old 09-05-2017, 10:39 AM   #6
Tires are good, not new. Didn't look closely at them but still lots of useable tread. I should've looked at the date stamp. The seller is asking 5k each for the three
Old 09-06-2017, 09:09 AM   #7
IWC Bus's Avatar
Chassis: A3RE
Engine: 3126 Cat
Rated Cap: 33220 GVwR
Cat c7 good motor
Sent from my VS835 using Tapatalk
The Rev.
Don't Fret God's Not Through With Me Yet!
IWC Bus is offline   Reply With Quote
Old 09-06-2017, 11:10 AM   #8
Originally Posted by IWC Bus View Post
Cat c7 good motor
If you can afford Cat service and parts it may be an ok bus. But I think for the money you'd do MUCH better at the auctions.
Old 09-07-2017, 08:42 PM   #9
I would do much better at the auction. I thought the price was high but it's the style of bus I'm looking for. Most busses here are conventional nose and those that are cab forward are almost always pushers
Old 09-07-2017, 08:53 PM   #10
Tread depth is something to look at but not the decider on tires. The tire age and sidewall condition are the real tale.
You can buy a bus with new tires for the same money you will pay for a bus with used tires.
Expensive Cat motor parts prices and only at Cat dealers.Not good when the dealer is miles away on weekends and holidays . You can buy Cummins parts from a lot of parts stores right across the counter.
Tires plus Cat motor = Keep looking.
Old 09-07-2017, 09:07 PM   #11
Cat parts don't scare me away, I work in the towing and recovery industry, so I've got connections with dealers. I understand the concern though, most of our fleet is dt466 or Cummins 12v.
Old tires are a concern though
Tapatalk
Old 09-07-2017, 10:33 PM   #12
Engine: 8.3 Cummins, 643
Looks like a high top 6'6" bus to me, I'm guessing because of the hump behind driver area. If your not planning a raise the extra 6" is a big deal when looking at a bus. Unless your short like me I can't really Tell about the tires but I would date them even if they look good. Old tires can still look good at a glance. It sounds like the C7 has provided a lot of people with great service the only substantiated drawback I have heard is the cost of parts. if you have an in on parts all the better. I wouldn't pay 8k for it but at 4-5k wouldn't be outrageous Sometimes people get really lucky at the auction sites so if your looking for a great bargain that seems to be the way. Like buying any used vehicle it's kind of a gamble.
Jacob is offline   Reply With Quote
Old 09-07-2017, 10:35 PM   #13
Tapatalk
Look at it this way. The dealers are closed on holidays and many many miles from where you and the wife and kids are broke down and they have to be in shcool the day after the last holiday and the dealership reopens the same day.
Freedom of choice.
PS. When i see worn or old tires i then wonder what else had been let go if they are planning a phase out of that bus. Crawl under and look all over. I have a wonder about the brakes and exhaust. Is there a oil spot under it?
Old 09-07-2017, 11:10 PM   #14
Freedom of choice.
Your point has merit. One isn't likely to find A Cummins or a Detroit dealer Open in such a circumstance either, and I don't walk into AutoZone and buy a lift pump or an injector harness on a Sunday
Old 09-07-2017, 11:17 PM   #15
The bus is 65 miles from home. If it's still there when I go back that direction next week, I'll investigate further. I did start and move the bus in the lot and seen no visible leaks. I done a basic pretrip on it but didn't crawl under it. Gravel doesn't agree with my body
Old 09-08-2017, 08:24 AM   #16
I am not trying to change your mnd. So many others read all threads for knowledge. Gravel doesn't like me either. I didn't crawl under my Bus and find out i needed to replace the exhaust from just past the muffler back. Even though the tail pipe coming out back looked relatively new. How much to fix? Maybe $500.00. I don't know. I regret that i didn't strap on my knee pads and do the crawl.
Old 09-08-2017, 10:26 AM   #17
you dont need $500. just mig welder n some pipe,, and maybe something to patch or make muffler. tires from les schwab. is simple
Old 09-08-2017, 11:18 AM   #18
Traveling
Rated Cap: '00
Tough to weld rusty exhaust. Ryder fleet will ship to your door- reasonable. Buy any 10' stick of tubing locally- orielly.
