Old 09-04-2017, 11:09 PM   #1
What's this bus worth?
I came across a group of Thomas busses for sale. Here's a couple pics of the one I'm interested in. What do you think it's worth? I am hesitant about buying a bus yet because I have word that there'll be a windfall of busses on the market here soon. Opinions?
Sent from my SM-J700T1 using Tapatalk
cwol97401 is offline   Reply With Quote
Old 09-04-2017, 11:14 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Caterpillar C7 EFC7210
5800 hours
What state? Rust?
Old 09-04-2017, 11:32 PM   #3
Oregon no rust visible. There's no salt on the roads here and it's got markings hinting to the valley.
Old 09-04-2017, 11:40 PM   #4
The vintage and shift quadrant suggests you have a MD3060 5-speed OD transmission.
At a guess the way in which the bus is spe'c'ed it most likely is not a 250 HP engine and more likely in the 210-235 HP range.
It will not be a powerhouse on the hills but it should cruise very easily at 60 MPH depending upon the gearing in the rear end. I came across one that had a C7 250 HP engine with really short legged rear gears. It would take off from a stop like a scared rabbit but it tached out at 57 MPH.
Since it is from OR it most probably does not have any rust.
I would guess the asking price is going to be in the $5K-$7.5K range with a reasonable sale price in the $3.5K-$4.5K range.
Old 09-05-2017, 09:37 AM   #5
Traveling
Rated Cap: '00
2005 - electronic, not too many emissions yet
2000 Series trans, says sticker, so doubtful md3060
Caterpillar C7 EFC7210 would be: Electronic Fuel C7 210 HP ...guessing.
usual disclaimers
tire condition?
Old 09-05-2017, 10:39 AM   #6
Tires are good, not new. Didn't look closely at them but still lots of useable tread. I should've looked at the date stamp. The seller is asking 5k each for the three
Old 09-06-2017, 09:09 AM   #7
IWC Bus's Avatar
Chassis: A3RE
Engine: 3126 Cat
Rated Cap: 33220 GVwR
Cat c7 good motor
Sent from my VS835 using Tapatalk
The Rev.
Don't Fret God's Not Through With Me Yet!
IWC Bus is offline   Reply With Quote
Old 09-06-2017, 11:10 AM   #8
Originally Posted by IWC Bus View Post
Cat c7 good motor
If you can afford Cat service and parts it may be an ok bus. But I think for the money you'd do MUCH better at the auctions.
Roll Your Own Build Thread
Old 09-07-2017, 08:42 PM   #9
I would do much better at the auction. I thought the price was high but it's the style of bus I'm looking for. Most busses here are conventional nose and those that are cab forward are almost always pushers
Old 09-07-2017, 08:53 PM   #10
Tread depth is something to look at but not the decider on tires. The tire age and sidewall condition are the real tale.
You can buy a bus with new tires for the same money you will pay for a bus with used tires.
Expensive Cat motor parts prices and only at Cat dealers.Not good when the dealer is miles away on weekends and holidays . You can buy Cummins parts from a lot of parts stores right across the counter.
Tires plus Cat motor = Keep looking.
