Old 06-09-2015, 11:50 PM   #1
wooden roof adition? how to?
I've got an old 1965 shortie (16 ft) bus GMC that I wish to turn into an office or shop. My idea is to build a wooden roof right on to the top of the bus. The roof would a) keep it cool b) minimize leakage (there is some) and c) look super cute.
The bus will not really be on the road much, although it may get moved from time to time.
Has anyone done anything like this?
I'm looking for pictures showing clearly where to begin.
I'm not super construction savy and don"t know how to weld, but could possibly hire help if needed.
I am also willing to learn and give it a really good shot myself if it seems realistic.
TIA
Jasmine.
jasmine is offline   Reply With Quote
Old 06-10-2015, 12:19 PM   #2
You might consider something lighter weight than wood. Up that high, added weight can be problematic. Aluminum is pretty easy to work with ( nuts, bolts & pop rivets) and could provide the cover you are looking for. The old school safari Land Rovers all came with a "second roof" a few inches above the real one for the same reason. That way...it was always "in the shade".
Old 06-10-2015, 01:51 PM   #3
ElizaHasAPlan's Avatar
I've seen a lot of decks on buses, and I've seen gable roofs on buses that had a house structure built around it, but I've not seen a gable roof directly on the bus itself. Like Tango said, that probably has to do with weight issues.
Here's the house/bus conversion with the roof I'm talking about: Our Cora Bean: Tiny House Extravaganza: House Bus Tour
ElizaHasAPlan is offline   Reply With Quote
Old 06-14-2015, 10:02 AM   #4
Year: 1959
Chassis: 1959 Chevy
Engine: 350
check out a book called Some Turtles Have Nice Shells
sky nighthawk is offline   Reply With Quote
Old 06-14-2015, 11:04 AM   #5
Engine: 190hp 5.9 Cummins
I own that book.
Old 06-14-2015, 04:49 PM   #6
Thanks for the advice, folks. In all honesty I'm not sure what I'm going to do yet.
Will check out that book though.
Old 06-14-2015, 04:59 PM   #7
OK, cora bean's tiny house bus is totally amazing! I'm going to have to scour that blog, do they talk about building the bus-house?
Old 06-15-2015, 12:10 AM   #8
And can you explain to me what you mean by "the house is built around the bus."
Old 06-15-2015, 12:51 AM   #9
They built outside of the metal bus shell, VS building inside like most do.
The shed I live in is built outside of the 16 foot metal shell of a bus body.
Studs, insulation, and sheeting all outside of the metal.
Old 06-19-2015, 01:54 PM   #10
Nat, do you have pictures? I am very interested in this idea.
Old 06-19-2015, 06:06 PM   #11
rvingoffgrid's Avatar
Coachwork: happy camper RV repair
Chassis: international
Engine: 360 international
Rated Cap: 66 passenger
in the early 60's GMC and MCI built double roofed buses that where shipped to places like egypt and the middle east where its all desert. the purpose was to be able to air condition them. with out the air gap between the roofs they found it almost Impossible to keep them cool. having said that, what your wanting to to isn't that. we build tiny houses on bus chassis. we strip the bus body off right behind the driver and replace it with a house. we use metal studs and framing, with metal on the roof. we use a bonding agent from 3M to bond all the pcs. together instead of rivets or screws, the reason is that the bonding agent will absorb the road vibrations and stay together where most other fasteners will work lose over time. if you want to lay a roof over the bus roof as has already been mention you have to watch your weight to prevent a top heavy un-drivable coach unless you put training wheels on it or a active suspension. it can be done and its not that problematic. need to address a couple of issues and your off. using metal studs is a great way to do it and cover it with metal tin or aluminum i have also sean a person who bonded wood shingles right to the metal roof of the bus. it was a very interesting and different look but worked well for many years and it didn't leak also added insulation value to the roof he used the same 3M product to bond the shingles to the metal where the sides meet in the middle of the bus he ran a ridge row.
rvingoffgrid.com
rvingoffgrid is offline   Reply With Quote
Old 06-19-2015, 10:53 PM   #12
It starts on this page.
Nat_ster's Haul All - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
However, I would not try building that for regular road travel.
bus, roof, school, wooden
