Old 07-24-2016, 05:42 PM   #11
Okay an update
I got up this morning and was on a mission to find the noise that made me call a rollback.
Jacked up her rear end and put on jack stands, then pulled off wheels after spinning them in neutral... No noise, so I crawled under her with a few pry bars and u-joints checked out good
So I pulled diff cover (8.5 dia 10 bolt) fluid looked good, no metal and no chunks, and back lash felt good
Rotated assembly
No missing ring gear bolts, and no broken teeth, so I pulled carrier pin and spider gears, no cracks and not broken, everything spun good
So I pushed axles in and pulled c-clips and side gears, all good and axle bearings were good
So next was carrier, bolts out and a rag stuffed into pinion gear and a pry bar carrier out and bearings/races looked good
No pinion movement front to back....
Very weird at this point...a loud banging that was very loud and unnerving... Called the wife out to talk through the parts as I reassembled the rear end
I was like WTF? I felt and heard the noise...I was under her fixing gear shifter when I noticed the the washer welded onto the drive shaft for balance was whiney and ground up...less than .020 clearance (a small paper clip wouldn't fit)
So knowing how much a rear end can move while flexing etc....I grabbed cut off wheel on plunged up a 3/16 from edge and had almost 1/4 inch clearance....we test drove to town and twisted her pretty good...NO noise...so that is fixed
Next leaks and stuff
25 years and 3000 miles on new speedometer we installed
C-ya'll
Old 07-24-2016, 08:58 PM   #12
My kind'a fix!!! Excellent!
Old 08-14-2016, 04:23 PM   #13
well we went to the local fundraiser for HS scholarship, 70+ cars and we actually got top 25 with no interior or anything
so I wanted some tunes (these are low $$ parts...it will be listened to maybe 40 hrs a year
so this looked bad and so none 1930"s
stopped at local "antique store" and saw this
brought it home
1960 or 70's shelf liner...gone
test fit
marked and cut
another test fit (had to leave wood for hinges)
into car test fit
looks better now...just have to finish truck some more
Old 08-14-2016, 05:42 PM   #14
Bansil, that is so cool. The first generation boom box. Jack
Old 08-22-2016, 07:22 AM   #15
Went to local winery for a tasting
and on the way home we drove down Copperhead rd...feeling like gangsters
[youtube]
Old 08-22-2016, 07:35 AM   #16
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Man thats classy!
Roll Your Own Build Thread
Old 08-22-2016, 09:44 AM   #17
Old 08-22-2016, 09:47 AM   #18
Just way too outstanding! Love the old railroad trunk...looks right at home.
Old 08-22-2016, 09:48 AM   #19
Man thats classy!
Thanks CB
She is def. classier than the driver , we were listening to 30/40's music on pandora, wifey says "We need to find period correct clothes for Sunday drives"
I said "Sweet, a fedora and a Tommy gun"
She->
Should be fun
Old 08-22-2016, 10:16 AM   #20
Just for the record...just a year or so before that Chevy was built...you could still buy a .45 cal Thompson through your friendly neighborhood hardware store.
