Old 06-24-2005, 04:27 PM   #1
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
400K sounds like it might be on the high end of where you'd want to buy -- especially with an Allison auto, and especially if they have been towing heavy stuff with the Allison auto. But I honestly don't know enough to give an educated opinion. I'm just basing it on stuff I have read (I do have an Allison AT540 in my bus, though, and it seems to be okay -- praying.... The Allison tranny's get knocked a lot, but there are a lot of them out there running fine.
OTOH. A used Allison auto can be had for about $350 or $400, and would probably cost as much to install. If you have problems with the tranny, it wouldn't be the most expensive repair job you could encounter.
Old 06-24-2005, 11:06 PM   #2
Coachwork: Ward Genesis
Engine: DT466/MT643
RUN AWAY FROM THIS BUS AS FAST AS YOU CAN! The 8.2 Detroit is a complete boat anchor. You're better off with a used unicycle with a flat tire.
Jarlaxle
Old 06-25-2005, 06:36 PM   #3
lapeer20m's Avatar
GMC transit bus, rear engine. Are you sure it's not a DD 6v72, or 8v72?
neither of those would come with the allison at545 since they sit in the GMC transits sideways(tranverse?) They had a funky V drive trans, but i forgot who made it. They're not the most ideal bus for over the road travel....but then again, neither are most of our skoolies! The DD 6v or 8v motors are excellent engines, last forever, and are cheap to rebuild. Someone made a remark that they barely have more moving parts than a chansaw. They are 2 stroke motors, and have an excellent exhaust note if you ask me.
I've also heard very bad things about the 8.3 DD. It's commonly considered to be quite a piece of junk, it seems unlikely that it would even go 400K miles.
Old 06-26-2005, 06:07 AM   #4
Engine: DT466/MT643
I have my doubts most 8.2's would make it 40K; I have heard of pushers with 8.2 Jimmys. From what I've heard, a 3208 Cat isn't an uncommon swap.
The V-drive trannies are made by Spicer (VS-2) and Allison (almost everything else).
Jarlaxle
Old 06-26-2005, 10:49 AM   #5
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Hi Brian,
If you're looking at a GMC Transit, only two come to mind. The two that were built, as a true transit, are the New Look (aka Fishbowl), and the RTS.
The New Look used to come with an assortment of Detroit Diesels. They came with either a 6V71 or a 8V71. Some of the later models were repowered with a 6V92. The transmissions used on these transits were V700 series (V730 etc.) and the Spicer VS and VH series.
The RTS was the last model transit that GM put out and it was also powered the same as the New Look.
I, myself, was looking at a transit, but I decided to go with a Skoolie instead.
Robert
Roasting8 is offline   Reply With Quote
Old 06-28-2005, 07:57 PM   #6
Engine: DT466/MT643
Some RTS transits had a 6V92 from the factory. Also, the later ones had Detroit Series 50's.
Jarlaxle
1982 GMC TailGator tailgator11 Skoolie Conversion Projects 3 11-03-2014 10:52 AM
1982 Ford B600 gas (first bus) chev49 Skoolie Conversion Projects 14 04-03-2013 02:21 PM
SOLD: FS: 1982 Chevy C30 dually w/454 big block baadpuppy Classifieds | Buy, Sell, Swap 3 05-18-2009 09:27 AM
1982 Thomas Saf-T-Liner ER (pusher) for sale (WA State) Les Lampman Classifieds | Buy, Sell, Swap 3 05-17-2008 10:43 PM
1982 Thomas bus for sale Wolfman Classifieds | Buy, Sell, Swap 3 03-10-2006 09:13 PM
