Old 05-05-2019, 08:29 AM   #1
Coachwork: MCI
Chassis: 96A3
Engine: 6V92
2 random questions
Busses are so cool.
Does anyone know where I can get a cabin air filter for a 2000 bluebird all american? Its a metal frame, foam element filter.
Also, I found am outlet on the drivers side front of the bus. What's it for??
Thanks!
Mtrdrms is offline   Reply With Quote
Old 05-05-2019, 08:59 AM   #2
HazMatt's Avatar
Chassis: IH 3800, 8 window
Not acquainted with Bluebirds, but from the image, I'd fab one out of aquarium filter foam & spray adhesive...
Did the bus originate in the NE? Chances are good it's for an engine block warmer. Should ought be able to back trace the wires.
It looks more ergonomically friendly than mine, mounted low on the front bumper...
(Prolly not, just read your intro post- rear engine. D'oh!)
Old 05-05-2019, 10:49 AM   #3
Chassis: IH
Outlet is probably for a block heater. That's my guess.
Old 05-05-2019, 11:24 AM   #4
Engine: TE 444
Rated Cap: 12
You can buy rolls of air filter material you can put on the backing mesh you have
Old 05-05-2019, 08:23 PM   #5
Coachwork: MCI
Chassis: 96A3
Engine: 6V92
Thank you! Just ordered some material.
« green bus | Paint »
