Old 02-04-2018, 03:10 AM   #1
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
315/85 22.5 steer tires???
I am currently running 295/75R22.5 tires on 22.5 x 8.25 Hub steelies, but they are ripe... ...they are original equipment (bus has 26K mi).
I am easing into this painful expense by getting the Alcoa rims now and wanted to run a 315/85 22.5 for steer tires, which means I need a 9" rim up front.
It'll all work mechanically, just wondering if it'll fit & if anyone tried this on a TC2000 or can talk me down from this ledge???
I did find the coolest tire calculator: https://www.tacomaworld.com/tirecalc....5-315-85r22.5
Thanks !
Old 02-04-2018, 09:29 AM   #2
Not sure what your current situation is in front, but be sure to confirm that the wider tires will clear everything at full lock.
Old 02-04-2018, 09:44 AM   #3
Traveling
Rated Cap: '00
That is the kicker, Tango- you don't know until you buy them and try.
The dump truck guys run those bigger wheels up front.
Old 02-04-2018, 10:11 AM   #4
Worst case scenario you can always re-set the stops. Best of luck with it.
Old 02-04-2018, 12:22 PM   #5
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
I refitted a few of our trucks Petes and Freightshakers w/315's so as to be legal on front axle weight from 11 22.5s and had only sleight clearance issues on full lock to lock barely rubbed springs on rear of front outer springs I would think it should not be an issue but axle geometry might be different on a skoolie.
Gdog 5651 is offline   Reply With Quote
Old 02-04-2018, 12:31 PM   #6
Chassis: Bluebird
Rated Cap: 74
Another consideration is that steering component wear is acclerated by the wider flatter imprint of a 315 over an 10 or 11 22.5 so unless you need the additional weight carrying capacity of the 315 I probably wouldn't do it.The wider footprint can also cause wandering if the axle wasn't designed for them.
Old 02-04-2018, 12:33 PM   #7
Traveling
Rated Cap: '00
Thanks- I might loose a tiny bit of turning radius, but looks doable (fingers crossed). I'd really like the extra bit of tire under that heavy front end.
