Old 05-21-2016, 08:32 PM   #1
Coachwork: Thomas Saf-T-Liner
91 Thomas Trailer hitch
Just thought I'd share this in case any one else with a similar bus is looking for a trailer hitch.
I installed a curt 15302 class v hitch on my bus today and seems to fit pretty well. I wish I didn't have quite a much drop but other than that no complaints. It even lined up with two holes that were already in the frame so only had to drill 4.
Bus is a rear engine 1991 Thomas saf-t-liner.
Sent from my XT1080 using Tapatalk
nwarner2010 is offline   Reply With Quote
Old 05-21-2016, 08:38 PM   #2
I think you want the drop for most things you will haul... though they make drop hitch receivers.. but that drop seems reaosnable so you dont have so much a tenendancy for trailer sway..
Old 05-21-2016, 09:24 PM   #3
Yes, keep the hitch as snug to the bumper as possible and achieve any additional necessary drop with the ball. This way when you're not towing you're also not 'bottoming out', or dragging the frame every time the back end dips.
jake_blue is offline   Reply With Quote
Old 05-30-2016, 09:59 PM   #4
RC000E's Avatar
Coachwork: Ford
Chassis: E350 #Vanlife
Engine: 6.8 V10
I just picked up a 1998 Thomas SafTLiner...this is a great piece of info here, as I need a hitch setup for sure. Thought I was going to have to fabricate.
RC000E is offline   Reply With Quote
Old 06-29-2016, 01:29 PM   #5
Are you going to tow your car?
If you do,,I would love to know how you'd do the wiring for the female end for lights. I already have the male end on my jeep.
peace,
Mert
AnnaMert is offline   Reply With Quote
Old 02-04-2018, 03:41 PM   #6
Rated Cap: 28,000
What is the span of the hitch?
what is the width of this particular hitch? Iím trying to figure out if itíll fit a 2000 Blue Bird CV200 45ft front engine.
Nsnodgrass73 is offline   Reply With Quote
