Old 05-19-2009, 08:24 PM   #1
Re: 93 BlueBird TC2000 FE 72/40 ft
Welcome!!
Abbott is offline   Reply With Quote
Old 05-19-2009, 08:55 PM   #2
lapeer20m's Avatar
almost every bus i've owned or worked on had the exact same alternator. It's a very common alternator at big truck parts stores, and probably any alternator shop has at least one sitting on their shelf. A leece neville....the housings are all the same, but there are a couple of internal options. they come rated as low as 105 amps to over 250 amps. I like to get one that has at least 130 amps. A bus with it's lights and five heater blower motors and other accessories can use a ton of current. The other option is to be connected to the ignition, or to be a "1 wire" alternator.
here is one on ebay for cheap:
http://cgi.ebay.com/ebaymotors/PREST...ayphotohosting
Old 05-20-2009, 11:25 PM   #3
swinada's Avatar
Welcome to the best SKOOLIE site on the WWW.
For your problem with the DC power, i would first check the easy stuff like the drivebelt. It might be alittle loose and hence the alternator is not turning properly or it is slipping. A belt is cheap and might solve your problem. Also check the connection from alternator to battery and ground, if they have corroded in the 2 years it was sitting you might not be getting the power from the alternator to the system. Always Easy - Cheap things first and then expensive stuff.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 05-20-2009, 11:29 PM   #4
swinada's Avatar
lapeer the e-bay link you posted does not seem to be a good a deal. I would never pay that much for an untested used Alternator. For a few bucks more you can pick up a brand new one at your parts store. I paid 150 for mine in Canadian so I doubt you guys in the states pay more then maybe 120 for a new 150AMP alternator.
Old 05-21-2009, 01:37 PM   #5
phillbus914's Avatar
I have the same bus & I dread the day my alternator fails... have you seen where they are on a TC2000?!
you can almost kinda see where it should be.. there to the right of the fan...
Good luck, and post pic's & directions if you do end up replacing the alternator.
My Old Bus :(
Old 05-21-2009, 01:49 PM   #6
nothing like working on a diesel engine in the livingroom, how much access is there from underneath and out front? IIRC some of the wonderlodges had swing away radiators that really helped with engine access.
Old 05-22-2009, 08:40 PM   #7
ha! I'd think posting pictures would be easier than making an entire website...
just copy the image location (from photobucket, or here on the gallery on skoolie or wherever) then click the Img button at the top when making a post and put the image location in between the brackets... like this,
[img]image_location_here.jpeg[/img]
My Old Bus :(
Old 06-12-2009, 05:17 PM   #8
swinada's Avatar
Originally Posted by BIG-BIRD
Thanks to "swinada's" great instructions on how to post a picture, I learned how to do it.
Thanks "swinada"
Hey, you're WELCOME Glad I could be of service.........
Old 06-12-2009, 05:24 PM   #9
swinada's Avatar
Kind a sucks to get stuck in your own yard. Hope you own the place and dont have to pay a landlord for damage done to the lawn.
That wheelchair lift will sure come in handy when you start loading all your boxes and heavy stuff for the move.
You say you kind of bought this bus uninformed, at least you talked to a mechanic. For us it was even less informed. Told a friend to buy me a bus at the auction if they go around 1500 $. Half an hour later i was owner of a 40' bus that I never have seen or knew nothing about. We never before really looked at 40 footers always shorter ones. But now i am glad we have the big one. Maybe my mind changes again once we actualy start camping with it.
Wish you all the best on your move, and then happy converting.
Old 06-12-2009, 05:44 PM   #10
Chassis: Ford B700
Engine: 5.9L Cummins
I got my bus from them too. Very vague descriptions and it was a complete mess. The pictures on the auction from what I could gather were old. Apparantly the day before I picked mine up another guy came to get his, paid for it then drove it in a circle and refused to take it. The description said the hatch was missing so I knew there would be some water damage, it did not say that it had been out of service for almost 2 years and sitting in the weather for that long. It did not mention the drivers side window was left open for this period of time as well creating corosion all in the panel. Every other municipality seemed to be pretty honest and forthcoming with any issues so I assumed this would be the same, shame on me for assuming. The mechanic and foreman were very nice and helpful which took away some of my initial frustration with the deal.
kamoo is offline   Reply With Quote
Bluebird TC2000 - good bus? vonslatt Conversion General Discussions 36 07-28-2018 04:00 PM
1997 Bluebird TC2000 Turbo 8.3L cazzthespazz Classifieds | Buy, Sell, Swap 3 04-15-2014 12:00 PM
1998 Bluebird TC2000 RE for sale mightybus Classifieds | Buy, Sell, Swap 0 10-23-2012 08:01 PM
Comparing Bluebird TC2000 and All American dentarthurdent Conversion General Discussions 20 12-22-2007 05:02 PM
FOR SALE: 1991 BLUEBIRD TC2000 texascadillac42 Classifieds | Buy, Sell, Swap 5 12-04-2007 10:53 AM
