Old 06-01-2011, 02:19 PM   #1
GreyEagle's Avatar
Advice, thoughts, please
Found this one on ebay
http://cgi.ebay.com/ebaymotors/Internat ... uses#v4-38
worries, big bus, 444E engine, 193,000 miles
likes, diesel, Allison 4 sp, rear engine, storages bays
any advice before?
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 06-01-2011, 02:35 PM   #2
frank-id's Avatar
I looked at the Ebay information
This looks like a 40 ft bus, but cannot determine the length. The milage is high but to protect the buy, ask for a compression test. The first weak point of these engines is the head and valves. Never believe what a seller says. Always discover any facts your self. I have a BB International 7.3 non electronic and no turbo. These engines are not high horsepower. Both my 7.3 engines needed the valves to be reseated. An airline into the glow plug location will show where the compression leaks are. This test is after compression has been tested. Compression should be about 385- 425 pounds of pressure. Ask to view all the bus repair records.Compare other bus selling prices. Demand seems to be at a low point when buying a bus. Frank
Veteran's Day Thoughts... Tango Everything Else | General Skoolie Discussions 4 11-11-2012 09:12 PM
Winter Thoughts thrash Conversion General Discussions 1 09-20-2011 01:50 PM
Some thoughts on converting a bus to an RV baadpuppy Electrical, Charging and Solar 19 05-14-2011 07:51 AM
My floor thoughts opus Conversion General Discussions 4 07-24-2010 09:32 AM
91 All American, FE, any thoughts? BBTC2K Everything Else | General Skoolie Discussions 15 10-26-2007 05:17 PM
