Old 04-13-2016, 10:57 AM   #1
Air brakes not working...?
Much needed day off so decided to work on the floors of our new bus. Drove it around the block, backed it in and worked for several hours. Fired back up to go to the store and getting no pressure on the air gauge, chime going off and brakes are locked...I'm new to the bus thing and the forum, searched thru here a little bit but didn't find a direct answer. Any help??
CHATHAM is offline   Reply With Quote
Old 04-13-2016, 10:57 AM   #2
Oh btw this is a 95 3800 international
Old 04-13-2016, 11:05 AM   #3
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I hope it's simple like a leaking valve and not a compressor. I had a valve that was leaking. I think it was $50 for the valve from Intl or close to that. It wasn't hard to install. Are you building pressure?
I'm hungry!
You Gotta Let Me Fly
Old 04-13-2016, 11:11 AM   #4
Doesn't seem to be building any pressure. But it happened in the course of driving it parking it and trying to drive it again in an hour or two..?
Old 04-13-2016, 11:11 AM   #5
Chassis: International 1753
Engine: 6.9 International
Basic course on air brake operation.
My guess is either your compressor is junk, the governor isn't allowing the compressor to pump air, or you have a large leak somewhere.
Booyah45828 is online now   Reply With Quote
Old 04-13-2016, 11:28 AM   #6
Thanks for the link
Old 04-13-2016, 11:40 AM   #7
Let us know what it was, good luck
Old 04-13-2016, 12:05 PM   #8
And...always check the drain valve. If not fully shut...leak down.
Old 04-13-2016, 12:18 PM   #9
make sure you didnt toss the belt off the air compressor.. ive seen belts pop off sometimes when you shutdown a diesel engine.. esp if it momentarily spins backward for a 1/2 revolution or so..
Old 04-13-2016, 05:00 PM   #10
Chassis: Blue Bird
Engine: ISC 8.3
There's likely a shop air connection hidden somewhere on the chassis.... You might even be so lucky that it would have a male connector on it, easier to identify and ready to plug the hose from your air compressor into it (pay attention to whether it's the industrial or automotive shape, and whether your hose has a compatible female connector). These ports are used for airing up and releasing brakes when the regular air system can't be used. If you can find a shop air connection and try pressurizing from a portable compressor, you'll better able to determine whether you have an air supply or an air leak problem.
Old 04-13-2016, 06:13 PM   #11
turf's Avatar
an air governor is cheap and easy to try and fix......
the rest are tougher and more money.
Turfmobile Build Thread
