Old 07-27-2008, 05:53 PM   #1
Year: 96
Coachwork: ic
Chassis: int
Engine: t444e
air dryer help
Evey time the bus gets up to normal presure the valve pops on the botton of the air dryer. i push it back in and it builds air but then does it all over agein. anyonw know how to fix this ? thanks
icre96 is offline   Reply With Quote
Old 07-28-2008, 07:10 PM   #2
frank-id's Avatar
Re: air dryer help
There are several solutions to the valve discharging air. The valve could be defective. The compressor govenor is set too high or defective. Air system could be dirty with excessive oil and sludge. Use a mechanical air pressure gage and connect at over pressure valve. Start engine and not when valve opens. Usually top air pressure is at 120 PSI. My guess is the govenor is defective. These units are cheap and easy to change. Frank
PVC Clothes dryer lornaschinske Conversion Tutorials and How-to's 4 03-02-2011 09:54 AM
Which washer & dryer? Seeria Conversion General Discussions 4 08-27-2010 11:09 AM
