Old 03-07-2018, 09:15 AM   #1
Air Entrance Door
Interested in some pro and con thoughts on this system as compared to standard manual opening by hand. Preferences, issues, problems and how they work?Thank you!
Pine Sap is offline   Reply With Quote
Old 03-07-2018, 09:42 AM   #2
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
I have experience with only one air door - the one on my coach. It certainly works fine. However; I park for weeks at a time and I suspect I would run out of air at some point. So, I usually pull the air release/shut-off valve when I park (for an extended period) and just open/close the door manually. Mine has a manual latch inside which is keyed from the outside and that works great for me.
Not sure that helps...
JD - Full timer out west
My Adventures & Build
Old 03-07-2018, 06:28 PM   #3
Mine was an air operated inward folding door...
I opted to flip the leading piano hinge and make the center fold solid to create a 1 piece outward opening door. Haven't regretted it once in 18 months!
As a bonus, I pulled the air solenoid, shortened the line leading up above the door and tapped into the line to run an air nailer.
Along this page somewhere
http://www.skoolie.net/forums/f10/on...or-6272-2.html
Door lock here: it's also been flawless
http://www.skoolie.net/forums/f27/lo...s-14494-3.html
Old 03-07-2018, 08:37 PM   #4
Chassis: Saf-T-Liner ER
Engine: Cummins ISC 8.3 Allison MD3060
I have an air door question..
Can there be two toggles to open and close them?
Reason I ask is I was thinking I could have the normal toggle/switch in the cab that would open and close the doors, but then I could wire a keyed lock that would activate the contacts for a switch that would engage the open/close of the doors.
That would be a way of locking the doors when out.
I am just thinking aloud and wondering if that would work.
James
JamieJackson is offline   Reply With Quote
