Old 05-04-2019, 08:11 AM   #1
Chassis: A3RE
Engine: Cummins 8.3
Air tanks
Hi! I just got a BB all american and I love it! My question is, since it has air brakes do I need to drain the water out of the air tanks occasionally? Does the air system need any other maintenance?
Thanks!
Andy
Mtrdrms is offline   Reply With Quote
Old 05-04-2019, 11:20 AM   #2
Drain the water from the tanks every single day.
Old 05-04-2019, 11:32 AM   #3
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
If it has an air dryer you only need to before freezing weather.
Just make sure your air dryer is working and has a fresh element.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 05-04-2019, 03:39 PM   #4
Chassis: A3RE
Engine: Cummins 8.3
Ok, so the tanks that I found are under the front of the bus. Do i have to climb under there everyday? How do i know if there is a dryer?
2000 Bluebird flat nose rear engine
Old 05-04-2019, 03:54 PM   #5
There should be a pull cable coming off the tank attached to the outer skin of the bus. Just pull the cable a few seconds every time you get in to drive
Old 05-04-2019, 06:28 PM   #6
Chassis: Thomas
Engine: CAT 3126
Depends on your bus. Mine has no pull cable. You have to climb under and there are 4 tanks with brass valves that twist 1/4 turn, but like I said I do this only once in a while since I have an air dryer.
Mine are roughly mid-ship close to the fuel tank. They look a little like scuba tanks.
My air dryer is just in front of my rear axle, but my bus is a pusher. Iím sure it varies by make and model.
Crawl around following the air lines for a while and everything will start to make sense.
My Build Thread:
Old 05-04-2019, 06:36 PM   #7
I'd definitely replace the valves with pull valves ($7) if I had to climb under every time they needed draining.
https://compressor-source.com/collec...-style-drain-1
Old 05-04-2019, 08:17 PM   #8
My MCI had one and it worked just fine. However, if the pull is at much of an angle the release valve can be bent which will cause the tank to leak down quickly.
Old 05-04-2019, 08:24 PM   #9
I thought of that and noticed on this one it actually pulls to the side and not straight out.
This valve drains when the connected cable pulls the pin in the center of the valve to the side.
Old 05-05-2019, 12:17 AM   #10
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
My BlueBird TC1000 has a door just in front of the front tire, under the driver's side window and the electrical panel, behind which are three air-tank drain valves. Each tank has a tube feeding to a valve. Super nice.
One leaks a bit when it is really cold outside. I bought a new valve from a Peterson dealer in Eugene like the one on the far left in the pic, but the old is installed with what looks like that white liquid/gel Teflon stuff that comes in a tube like RTF silicone for your water pump. It hardens solid. I tried to torque it off, but it was straining the valve's mount! I decided it might be best not to deal with it on the road, as an air-tank is behind the panel of valves, and would likely need to be removed to fix the valve if things break trying to unscrew the stuck fitting. Maybe if I heat it just a bit with a mini-torch?
I've used that stuff before. No more! Stick with Teflon tape.
