Old 04-14-2012, 09:26 AM   #1
lornaschinske's Avatar
Rated Cap: 89
Algae Growth in Fresh Water Tank
Wasn't someone here having either problems or concerns on algae in their fresh tank?
Algae Growth in Fresh Water Tank Link found thru RV Travel Newsletter.. Handy little newsletter to subscribe to.
Fulltime since 2006
Old 04-14-2012, 10:03 AM   #2
Re: Algae Growth in Fresh Water Tank
That was me most recently,and that is a similar setup I was pointed to also,
Thank you for that link
Old 04-14-2012, 01:13 PM   #3
Rated Cap: 89
Might be a good idea to put it on black tanks as well. In case you have little ones prone to sending stuff down the toilet or if you goof up and do what I did recently.... I forgot to close the valve after dumping. After a week, I had the "Tower of Doom". It took a couple of days, a lot of water and an act that I would like to never repeat, to get the tank cleaned out. If/when we replace the black tank, it will be installed on a slight slope as will the grey tank.
Fulltime since 2006
Old 04-15-2012, 09:23 AM   #4
lots of rv black tanks have a sloping bottom.. the newer ones that i have do... well so do some of the newer grey tanks as well... makes it easy just to install it with the top level...
Old 04-15-2012, 02:28 PM   #5
Rated Cap: 89
The used black tank we put on the bus is old. Very old. It has a flat bottom except for a 6X6 with 4" drop where the drain is. We plumbed the vanity sink into the black tank but I must need to use more water. I did not have this problem with the sloping tanks on the Class C. I guess the slope right under where the toilet drops makes a big difference.
Fulltime since 2006
Old 04-20-2012, 06:24 PM   #6
Engine: DTA360
Rated Cap: 16
"The Tower Of Doom"... Hahahaha...
dirtygoat is offline   Reply With Quote
Old 05-01-2012, 01:01 PM   #7
Diesel Dan's Avatar
Engine: DT466/AT545
Yeah, I got a good belly-laugh out of that one! ...wipes eyes...
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Fresh Water Tank/2 A/C Units bluebird flatnose Classifieds | Buy, Sell, Swap 0 10-20-2010 09:53 AM
Fresh water tank for fuel? BUSBOZO Conversion General Discussions 6 10-13-2010 12:13 PM
Fresh water tank combo question BUSBOZO Conversion General Discussions 3 03-04-2010 08:13 PM
fresh water tank bocephus Everything Else | General Skoolie Discussions 5 12-21-2005 08:01 PM
Plumbing/Fresh water tank questions Branden Plumbing, Water and Waste 6 04-19-2005 03:30 PM
