Old 02-13-2007, 10:38 PM   #1
Year: 1980
Chassis: 3 axle (10 wheel)
Engine: GMC 6-71 T
Rated Cap: 97
Send a message via MSN to Coalforge
Allison shift point
have an Allison MT-644 behind a 6-71-T. The engine no load high
idle is about 2650 and the high idle under load is 2400. The
transmission shifts at 2100. This seems low on the power curve. I
would be interested in knowing other people's shift point and if it is low, is it
practical to raise the rpm where the shift occurs?
Thanks
Coalforge is offline   Reply With Quote
Old 02-13-2007, 11:14 PM   #2
frank-id's Avatar
The master of Allison auto trans
A good auto trans mechanic and shop owner in your area is....
Harry at Power Shift NW... Woodinville.. 425 487 1535
When ya call him, have all the data ready to tell Harry. He wants all the info on the trans tag. Harry has the books and lots of experience. Be ready with your engine type, number, type of bus, rear axle numbers. Harry will give ya lots of information and advice. I'm going to him shortly so he can change my trans shift points. Tell him, Frank, from Idaho gave ya this information.
Frank
Old 02-14-2007, 06:00 PM   #3
the_experience03's Avatar
How do they change the shift points on the mechanical
Allisons? Is it just a modulator swap like on a Turbo 400?
Old 02-14-2007, 08:17 PM   #4
frank-id's Avatar
Allison trans shift points
Allison determins shift points by, throttle position, govenor, engine type and application. The major adjustments are done in the valve body, with the Allison book, many years past experiences, and application. A farm truck will not have the same shifts as a bus or a local delivery truck. The rear axle ratio also affects the adjustments. Harry is da man. Frank
Buses that don't like to shift out of park? wirelessguyNY Ford Drivetrain 3 08-26-2011 03:52 PM
From the bacterial point of view Hex Alternative Fuels | Electric, Propane, Wood & Biofuels 0 12-08-2008 07:50 AM
Need suggestions for starting point.... Imaexpat2 Conversion General Discussions 15 03-02-2007 02:58 AM
I need a floor mounted shift tower frank-id Classifieds | Buy, Sell, Swap 1 06-13-2006 04:41 PM
transmission wont shift right glock17 Skoolie Conversion Projects 3 12-13-2004 10:18 PM
