Old 06-12-2009, 06:59 AM   #1
Re: Alternator Question?
fix the ground wire and see what happens, it may be the problem or the causse of the problem. if the ground wire wasn,t necessary the cost control weenies at the factory would not have let manufacturing install it.
Old 06-12-2009, 01:59 PM   #2
swinada's Avatar
Most electrical problems in a vehicle can be traced to a bad ground wire. Seen it many times that something goes haywired and your already thinking oh this is gonna cost so many dollars when in reality it was only a bad ground.
So fix your groundwire and at the same time clean the other contacts on that alternator and then try again.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 06-15-2009, 05:52 PM   #3
frank-id's Avatar
Most alternator failures are caused by poor battery connections or a poor ground. All connections need to be bright, shiny and clean. Use new nuts and washers with grease or electric grease. Too much grease will attract dirt. I have also used antiseize on all the connectors. The large bolt should get some anitseize as well as the adjusting bolt. The alternator choice should be based on use. The belt tension is also important as too tight a belt and the bearing will fail early and too loose, belt may slip and voltage will be low. I get hi amp alternators from Ebay. No failures yet........ Frank
Old 06-15-2009, 07:56 PM   #4
the_experience03's Avatar
That sure looks like a run-of-the-mill GM alternator. I'm fairly certain it's a 27SI, but it really doesn't matter. Any parts store worth a darn should have one on the shelf or at WORST the ability to get one within a day. They will probably even have multiple outputs available within the same case and clocking so you can probably get a higher output unit for a nominal increase in price.
*edit* Make sure you get that alternator tested before you spend money on a new one. Our buses have some pretty high electrical demands and it wouldn't surprise me in the least if you were discharging the batteries at anything below say 1500 RPM if you had enough stuff on. It's ok and perfectly normal. Modern cars do it all the time, but the computer won't let the idiot light come on when voltage drops so as not to scare drivers.
You might want to take your pulley off the alternator. There's a pretty good chance the new one won't come with a pulley because that alternator was offered in so many different vehicles with so many different belt configurations.
Old 06-17-2009, 06:04 PM   #5
Originally Posted by BIG-BIRD
vanguy67: LOL, yes, the rest of the parts are a little envious at the moment... I sure wish the rest of the motor looked as good!
Unless you southern boys are lucky it won't take long for that shiny new alternator to look like the rest of the motor.
Sounds like an honest mechanic! He's worth his weight in gold! You should take ALL of your mechanical business to him. If I ever have a problem in the area he'll get my money....
A good, honest shop is a rare thing these days so they need as much business as we can give them'...so they STAY in business!
Ahhh...we aren't ALL that bad.
alternator question LPTC Mechanical and Drivetrains 2 12-16-2014 02:15 PM
one-wire alternator question rv8flyboy Alternative Fuels | Electric, Propane, Wood & Biofuels 2 07-15-2014 09:26 AM
I am going to go see this bus today. Needs alternator? HELP chev49 Mechanical and Drivetrains 0 05-14-2012 09:31 AM
Rebuild an alternator the_experience03 Everything Else | General Skoolie Discussions 5 08-20-2006 05:21 PM
Alternator missing? BUSTED Conversion General Discussions 5 10-02-2005 10:02 PM
