Old 10-31-2009, 03:10 AM   #1
cheezypsnookle's Avatar
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
Re: Am I too tall for a bus??
i am 6 foot even and my blue bird is at 6'3 interior so i would look into a bluebird..
hope that helps
cheezypsnookle is offline   Reply With Quote
Old 10-31-2009, 09:50 PM   #2
GoneCamping's Avatar
While the measurements can vary from one make to the next, there are basically 3 different interior hieghts available, and generally speaking you can look at the outside roof line and tell which one is which. If the outside roof line drops a little right after the front panel, the ceiling height will be around 6' in the center. If it is a straight roof from the very front all the way to the back, it's likely to be around 6' - 3"
inside at the center, and if the roof line raises UPWARD after the front panel, then there should be around 6' - 6" inside at the center.
This is also why MOST people do a roof raise on their buses. I did not, but I'm relatively short at 5' - 7" and have no problem with the low ceiling...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 11-01-2009, 12:48 AM   #3
ezbme's Avatar
Coachwork: Thomas Transit Liner
Engine: CAT 3208 Turbo
Pete, AH you are never too tall. Look at Millicent & Smittys new ride!
I got lucky when I came across our Thomas Transit Liner. It does have the tall roof, 6'6" at center which is great as I am 6'3" tall & it does feel roomy.... Look into the Thomas buses with the higher roof, they are out there! I would love to raise a roof one day tho...
Jonathan
ezbme is offline   Reply With Quote
Old 11-01-2009, 11:08 AM   #4
I raised the roof on my bus 14". Then I framed in a flat drop ceiling with three and a half inches of fiberglass insulation above it. Finished height floor to ceiling is six foot eleven inches.
Abbott is offline   Reply With Quote
Old 11-01-2009, 09:50 PM   #5
Originally Posted by Smitty
Abbott, even though I just saw I had posted in your conversion thread, all I see are the dreaded "Red-Xs" in place of your pics. I didn't recall you installed a flat ceiling...anywhere I can see pics? Or are the Red-Xs on my end? Seemed like you "blogged" your project, got a link? I'd like to take a look at your ceiling.
Thanks
Smitty
Hi Smitty, my blog is off line due to ISP issues. I really like the way the flat ceiling makes the bus feel inside. If you want to PM me an e-mail address I will send you a few photos of the ceiling.
(I am taking off for a day or two sometime tomorrow afternoon)
Old 11-01-2009, 11:12 PM   #6
the_experience03's Avatar
I'm 6'5" and handle the 6' interior just fine. Sure, I wish I had more height, but it's really not that bad...unless you get a tuft of hair caught under a rivet head after a night of overindulgence.
Old 11-02-2009, 07:55 AM   #7
I would have to say that it depends on if your going to put a ceiling fan in...
My friend is 6'6". He lives in a (non)mobile home with a ceiling fan. His hair brushes the blades when he walks under it, and I have seen him forget to duck a few times while it was on... Lucky for him that it just barely misses skin (less than a quarter of an inch). ...Not that I think you will put one in, but just in case...
Do yourself a favor, Find a bus that you can stand tall in, or raise the roof.
How tall is it? EniRamBus Conversion General Discussions 7 08-19-2011 02:38 PM
Advice for tall newbie madpsalmer Conversion General Discussions 2 12-03-2009 11:34 PM
My tall bus baadpuppy Skoolie Conversion Projects 6 07-17-2008 11:54 PM
how tall are you? lapeer20m Everything Else | General Skoolie Discussions 13 02-28-2005 07:29 AM
