Old 12-29-2010, 12:34 AM   #1
Engine: DTA360
Rated Cap: 16
Ammo Can Rocket Stove...
So, I've been thinking about building a wood stove out of an ammo can after Lorna posted the link in the hobo stove thead... While researching some different types I started reading up on Rocket stoves... I figured I could turn the ammo can into a Rocket Stove...
The idea is to create a highly efficient wood burning stove that can generate a lot of heat with minimal fuel, while burning up almost all of the emissions except for co2 and steam...
Basically you build a burn box that you feed the wood into and air gets drafted in from under the wood... It drafts up hits the underside of the stove top and creates a torus sending the hot air around the chamber heating up the stove even more... Then makes it's way out the exhaust... By keeping the hot air in the chamber for longer it makes the stove more efficient... It also makes the wood burn way cleaner...
Here's a simple drawing that gives you an idea of how it works...
Here's the ammo can that I'm gonna use... I plan on building it upside down so the handle on top is still usable...
I have yet to see a stove built like this out of an ammo can, so this is not tested... There are simple wood burners and bbq grills out there, but nothing as far as a rocket type stove... Should be fun...
dirtygoat is offline   Reply With Quote
Old 12-29-2010, 10:45 AM   #2
Stuff's Avatar
Re: Ammo Can Rocket Stove...
if the exhaust is tall enough it should work. might have to drop a burning piece of paper down the exhaust initially to get the air flowing?
Old 12-29-2010, 11:04 AM   #3
lornaschinske's Avatar
Rated Cap: 89
Please be careful. Go to the hardware store and get one of those (fairly) inexpensive CO detectors. Watch out for buildup on the inside of your exhaust pipe.... no matter what kind of stove you end up with.
Here are a few more links on the instructables website for wood stoves... you may find some ideas to incorporate into your design (or you may find that some one has done exactly what you plan on...learn from their mistakes)
http://www.instructables.com/pages/s...1&q=wood+stove
http://journeytoforever.org/biofuel_...arth/me11.html
Fulltime since 2006
Rocket Heaters in Skoolies Seeria Heating, Cooling and Appliances 19 09-23-2017 01:48 PM
Rocket stove magic_bus Alternative Fuels | Electric, Propane, Wood & Biofuels 39 06-18-2015 07:48 AM
Wood Stove for Bus? Seeria Heating, Cooling and Appliances 0 12-15-2010 02:56 PM
Rocket Scientists??? C00LR Everything Else | General Skoolie Discussions 7 10-21-2009 01:36 PM
Which stove to install? Papabear Heating, Cooling and Appliances 15 05-11-2009 10:55 AM
