Old 04-15-2015, 06:57 AM   #21
Vlad,
having a long drive shaft could be a benefit!
You could place a transfer case about 4 feet from rear end and have the bus engine/tranny spin a prop
the boxes mud boggers use can handle the power/torque, and having an air shifted rockwell would eliminate the cable needed, just mount box backwards and use the front out put (4x4) to power prop
so who is building it? and when is the christening
Old 04-15-2015, 11:47 AM   #22
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
Originally Posted by bansil View Post
Vlad,
I can see one benefit having a long drive shaft it can be used as a long clothesline....
What are others?
Here is my conversion thread:
https://www.skoolie.net/forums/f11/98-bluebird-tc2000-conversion-2-feet-roof-raise-3-slideouts-9728.html
Vlad is offline   Reply With Quote
Old 04-16-2015, 02:37 PM   #23
Engine: 190hp 5.9 Cummins
Vlad,
Just weld a grain auger in place of the drive shaft and you would have a screw drive.
No prop needed.
