Old 04-12-2015, 12:51 AM   #1
PDBreske's Avatar
Rated Cap: 1
Amphibious bus concept
Here's an idea that's been bouncing around in my head for years. It's an amphibious bus concept using pontoons that stow over the roof of the bus and swing down on a support system for use on the water.
Road position:
Water position:
Here's a breakdown of the amphibious parts in mid-transition. The fixed supports tie into the vehicle chassis rails under the bus:
For water propulsion, I'm thinking paddle wheels roughly aligned with the drive wheels and a telescoping set of forks that extend into the spokes of the drive wheels and in turn spin the paddle wheels. The vehicle's engine could then provide both road and water drive without the need for a complicated water propeller hanging under the belly. The paddle wheels could be installed with a partial channel hull in each pontoon that allows for clean water into and out of the paddles.
For steering, maybe some kind of fold-up front-steer rudder that is controlled by the front wheel. Probably wouldn't need one on each side.
Obviously, a lot of thought would need to be invested in figuring out the total displacement of the vehicle to engineer adequate floatation, and I doubt the pontoons would float the vehicle high enough to just drive in or out of the water without scraping the floats on the ramp, so maybe some kind of telescoping supports for the outriggers that allow driving into the water in a high position, then lowering the floats for better efficiency on the water.
Can you imagine living full-time in a bus that also can cross lakes and slow-moving rivers? Each pontoon has over 100 square feet of deck space! Add a low-profile roof deck and you'd triple your floor space while on the water. And you could travel the length of the Mississippi from north to south on just a few gallons of fuel.
Read about the "Camel" RV Conversion project!
My first passion is photography. Visit my website to see some of my work.
Old 04-12-2015, 05:18 AM   #2
That didn't work out very good for the kid in the rover? Last year, he tried to drive around the world, when he got near water the pontoons were lowered etc
Old 04-12-2015, 08:03 AM   #3
Coachwork: ward
Chassis: international
Engine: dt360a
you wouldnt travel far in southern waters. you would get hung up on sandbars and stumps. thats why we use pirogues!!
i like the concept, it would be killer to drive right off the beach and catch supper. but think jet propulsion from rear of pontoons. it wouldnt foul as easy and would provide both propulsion and steering. think hydraulic pumps and motors........
Old 04-12-2015, 09:59 AM   #4
PDBreske's Avatar
Rated Cap: 1
While I like the idea of steerable jet drive, I worry that the system would be costly to implement and more complex than simple paddles. If the paddles were just simple boards with nothing to collect debris and offset from the axis to allow clean exit from the water, I think fouling would be minimal. I'll try to model something for the concept.
Given the water displacement of large, flat pontoons, I think the draw would be pretty shallow, thus avoiding most of the obstacles that may hinder a shorter, narrower boat with a deeper keel. Plus, it's not like I'd be exploring uncharted waters in my busboat.
Old 04-12-2015, 10:22 AM   #5
PDBreske's Avatar
Rated Cap: 1
Well, as a concept it's pretty cool, but the numbers don't work:
The floats as described displace about 21,000 pounds of water (48" wide x 18" deep x approx. 28' long x 2 pontoons x 62.4 pounds per cubic foot of water). That's not enough to maintain buoyancy at the vehicle's max gross weight, not including the weight of the amphibious gear which would undoubtably be several thousand pounds.
Increasing the floats' depth to 24" does bring the displacement up to 29,000 pounds and that would be enough to get the tires completely out of the water, but also would increase the road-going height of the rig to over 13 feet. Not to mention the weight of the floats when stowed would raise the center-of-gravity so high that I would fear driving on fast curves.
Anyway, it's fun to think about.
Old 04-12-2015, 10:30 AM   #6
PDBreske's Avatar
Rated Cap: 1
Although ... filling the empty spaces under the bus with floatation would alleviate some of the necessary pontoon displacement. ;)
Old 04-12-2015, 10:46 AM   #7
Ok sing along...
Row row row your bus........
dond is offline   Reply With Quote
Old 04-12-2015, 11:13 AM   #8
Engine: 190hp 5.9 Cummins
Gently across the lake.
Old 04-14-2015, 12:17 PM   #9
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Road position:
Water position:
looks good, you first.
I'm hungry!
You Gotta Let Me Fly
Old 04-14-2015, 12:41 PM   #10
Old 04-14-2015, 01:48 PM   #11
Honestly I was in search of one of these bad boys before I found out how insanely expensive they are...
bearbus is offline   Reply With Quote
Old 04-14-2015, 01:56 PM   #12
I would have pontoons to keep them from falling over with any kind of wake!
Old 04-14-2015, 02:02 PM   #13
you mean like this ?
like I was saying, they're CRAZY expensive..
http://boats.smartcarguide.com/listing/47683042/
Old 04-14-2015, 02:05 PM   #14
BUS + DUKW =
Old 04-14-2015, 04:21 PM   #15
PDBreske's Avatar
Rated Cap: 1
Kinda hoping to spend less than a million dollars.
Old 04-14-2015, 04:37 PM   #16
crazycal's Avatar
This one is less than a million bones.
Don't know what happened to my link. Here it is.
I'm hungry!
Old 04-14-2015, 04:39 PM   #17
well now you're just being picky
fine fine...
Just add a roof!
Old 04-14-2015, 04:40 PM   #18
May just be easier to add wheels to a houseboat!
Well, if you build it at least it will look like it cost a million. You do good work man.
Old 04-14-2015, 05:47 PM   #19
PDBreske's Avatar
Rated Cap: 1
Probably cheaper, too. LOL
Old 04-15-2015, 01:12 AM   #20
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
I think it is doable but not just buy taking a super heavy skoolie built like a tank and make it float.
Also I would use rear engine bus, because you will have power for your water propulsion right there and you don't have a monster drive shaft running along entire bus.
It looks like you are missing one part that can help to float... it is the bus "storage compartment". It can be converted in to a large float. I made my own storage which is 2' high almost 8' wide and almost 18' long and I could make it sealed all around with access from top. This large belly float will give extra 8k litres if used all.
I think it is doable but at what price?
Here is my conversion thread:
http://www.skoolie.net/forums/f11/98-bluebird-tc2000-conversion-2-feet-roof-raise-3-slideouts-9728.html
Vlad is offline   Reply With Quote
