Old 03-14-2018, 09:30 PM   #1
Annoying buzzer
Hey guys started doing the floor today and had to disconnect the rear heater now a buzzer is going off any ideas how to stop it other than reconnect the heater. (I think itís because of the heater)
Also my flooring is just 5 pieces of thin sheet metal is that normal?
Lherrlinger is offline   Reply With Quote
Old 03-14-2018, 09:33 PM   #2
Chassis: Saf-T-Liner MVP ER
I can't think of any reason why disconnecting a heater would cause a buzzer to sound.
Are you sure you haven't broken, or disturbed any of the door interlocks ... or even locked a door that should be unlocked?
Steve Bracken
Build Thread
Old 03-14-2018, 09:52 PM   #3
Hey guys started doing the floor today and had to disconnect the rear heater now a buzzer is going off any ideas how to stop it other than reconnect the heater. (I think it’s because of the heater)
Did you buy it stripped already? Most of the buses have just a steel sheet metal floor to seal it from the outside. Then a plywood subfloor goes down before the vinyl/rubber puke mat top floor.
Update your profile info now that you have a bus so we know what to refer to.
Old 03-15-2018, 06:38 AM   #4
Yea thatís what I thought as well no solid flooring was really weird to me , Iíll update my profile here in a minute itís an E450 6 window 2003 it has the 7.3 powerstroke. When I pulled everything up it was from top to bottom rubber Matt,plywood,5pieces of sheet metal overlapping , I canít believe there is no solid flooring
Old 03-15-2018, 06:42 AM   #5
Yea not sure either I’ll bet it’s the emergency hatch had some people checking out the bus and we’re messing with windows and doors, I thought I checked all but didn’t check the hatch. Is there any easy way to take out the heater to finish the flooring without spilling a ton of coolant?
electrical, floor, heater, help me!, noise
