Old 01-20-2008, 12:39 AM   #1
frank-id's Avatar
Anyone done an alcohol/water
Seems to be some horsepower and cooler inlet temps. Many systems available on the net. Google has lots of information.
this looks good.....
http://www.turbomirage.com/water Frank
Old 01-24-2008, 11:24 PM   #2
frank-id's Avatar
The advantage of water/alcohol
is a lower incoming air charge. It is said for every 100 degrees of lower temps there is a 10 HP power gain. My engine does not have an intercooler. A cooler for my 7.3 Ford diesel will cost about $700 with piping, plumbing and lots of fabricating hours. War airplanes used water/alcohol for a cheap horsepower gain. This cooling method is just for the long steep pulls. I know more horsepower is the best method, but horsepower is not free. The parts are fairly cheap to assemble a system. Propane is good too. Frank
Alcohol as fuel and making your own revoltindevelopments Alternative Fuels | Electric, Propane, Wood & Biofuels 38 10-11-2019 10:11 AM
help on black water and grey water hookups heath692 Plumbing, Water and Waste 8 04-18-2015 05:57 PM
Drinking Alcohol in a Skoolie Brian2417 Conversion General Discussions 4 03-09-2010 10:27 AM
Looking to connect .. using water/alcohol frank-id Everything Else | General Skoolie Discussions 0 01-02-2009 09:05 PM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
