03-08-2018, 09:37 PM
Anyone put washer/dryer in their bus?
My husband and I are looking into converting a bus to live in, but we want to make sure that we can put essentials into it to live comfortably and conveniently. Has anyone put a washer and dryer in their skoolie? I watched a YouTube video where they mentioned they were going to I think but I haven’t actually seen any with some inside of them. Let me know your thoughts and if you’ve done it!!
Thank you!
03-08-2018, 09:55 PM
Rated Cap: 37,400 lbs GVWR
Thank you!
I bought a hardly-used Splendide 2000 washer/dryer for cheap from someone else in the RV yard where I store my bus - he only goes pole-to-pole in RV campgrounds, never boondocking, so he never needs it. It will live in the kitchen next to the fridger, close to where the hot and cold water and drain lines are now. I'll probably use only the washer part if I'm boondocking somewhere arid such as in the desert, then just hang my clothes in the sun to dry, but the dryer function could be useful if it's damp or raining outside.
03-09-2018, 08:16 AM
Coachwork: AMTRAM
Chassis: INT
Rated Cap: Big Girl
Did on my bus, could not be happier I did, Washer will run on solar, dryer will not unless you have shore power or generator going. Does not take up a lot space either and the washer is a on wheels.
This was taken mid way in the conversion!
03-09-2018, 08:48 AM
Chassis: Saf-T-Liner MVP
Engine: Cummins
What Washer and dryer did you use?
I'm thinking about it as well, just wondering if there is a good old fashion manual washer that I can get.
03-09-2018, 09:00 AM
This is about as close as it gets...
03-09-2018, 09:18 AM
03-09-2018, 09:21 AM
Engine: Cummins
Originally Posted by Tango
Perfect!
03-09-2018, 10:59 AM
Engine: Dt466e
Rated Cap: 71
do you have the link for this one?
03-09-2018, 11:03 AM
Engine: Dt466e
Rated Cap: 71
How much water does that thing go through? Ideally i wouldnt run it unless i had hookups, but you could need it boondocking too
03-09-2018, 12:40 PM
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
My daughter bought us one of these as a Christmas present it is so small I'm pretty sure a pair of jeans and t-shirt would over load it. It doesn't really "dry" clothes we tried to return it but the shipping is as high as the price of the unit. I have seen the same or very near identical unit almost everywhere, I think the Chinese make it in one place and sell it in hundreds. It also doesn't get very good reviews by those who own them.
03-09-2018, 01:31 PM
I was only sharing because it's about the only manual washing machine out there I'm skeptical of any machine that claims to do the same as its bigger cousin
03-09-2018, 01:36 PM
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Yes. I went with a Kenmore 41003. Had a vented Splendide 2000 in my last motorhome and it worked well for me (solo).
03-09-2018, 03:12 PM
03-09-2018, 03:37 PM
Ya, those RV side by sides just spin dry, they don't use any heat. Perfect for our use if it had heat. Nice that they only cost around $125
