Old 05-17-2018, 11:00 AM   #1
Are people putting in rigid insulation correctly?
I was reading some technical specification sheets on one of the common rigid insulation board that people use. I noticed that one of them said it needs 3/4 of an inch to 3.25 in of dead air space the question is is it better to have one and a half inch of insulation with no air space or 1 inch of insulation with some airspace? And for your walls and ceiling which side should the dead air space be on?
estelle bus is offline   Reply With Quote
Old 05-17-2018, 11:09 AM   #2
Chassis: Saf-T-Liner MVP ER
You are reading specs that relate to standard construction methods, where an air-gap forms part of the overall R-Value of an installation.
In a bus there isn't room to incorporate those gaps. Don't worry about it.
Steve Bracken
Build Thread
foam, insulation, rigid
