Old 06-12-2015, 09:43 AM   #41
Chassis: B3800 Short bus
Originally Posted by austin1989us View Post
Also, the outside wall is being heated on the vertical edge.
Yes, of course. In the sun, the outside wall is being evenly heated. With A/C the interior wall is being actively cooled.
The bottom edge of the wall is cooler than the vertical side of the wall. It won't have the same effect as if the wall is being heated from the bottom (which would induce maximum convection).
True. We're dealing with this for the wall cavity:
Old 06-12-2015, 10:07 AM   #42
austin1989us's Avatar
Chassis: TC/2000
Engine: Cummins 5.9TA
Yes. Any idea how fast it's moving? Got an h value? What about the insulation that's there? I don't have modeling software to model this wall with.
This became a very involved discussion about the merits of putting new insulation in the walls. I understand that there are some strong opinions from those who've gone through the work of tearing out their interior walls. While I can see the benefits of getting in there, getting the old crap out, and fixing any rust; I don't see much of a benefit when it comes to heat transfer.
I'm not sure which way I'll go yet. I might be able to save a considerable amount of time and effort by not tearing down the original walls.
austin1989us is offline   Reply With Quote
Old 06-12-2015, 10:46 AM   #43
Coachwork: IC
Chassis: CE300
Rated Cap: 32
The bus will smell better after its all out.
Old 06-12-2015, 10:51 AM   #44
I was just going over the initial calculations and it doesn't actually take into consideration either the inner or outer sheet metal. I suppose they fall under radiant heat transfer?
It appears we will need an infrared heat gun after all.
The benefit for insulating the inner wall is this: it all adds up. For those who are interested in putting the time into having a long-term build and a well insulated space it makes sense. We can (affordably) insulate the dead space between the sheet metal while dealing with other notorious problems. We can reduce radiant and convective heat transfer in that zone to nearly zero. Then we can do the necessary step of insulating over the ribs. It's all accumulative.
I insulated between the ribs 3.75" thick and over the top of the ribs 1" for a consistent, flat insulated envelope to work with. Of course, I haven't tried the bus with only 1" XPS or spray foam over the entire inside, but from other jobs I've done in more favourable conditions I know that only 1" of XPS doesn't do a whole lot, though it's a nice addition to the outside of a building to reduce those accumulative thermal leaks. This bus I can use in the winter without a problem (our Canadian winter). The ribs and windows are still the weak point, but in its current state it does a great job while maximizing the available floor sq/ft (those oh so precious inches).
With the intention of creating a long-term livable situation... well, I just couldn't imagine NOT pulling those panels off, cleaning and insulating.
A short term metal tent? Just glue XPS over everything, then 5/8" plywood over the XPS with strategically placed screws to hold it in place while the glue dries and make sure it ain't going anywhere down the road. Another thermal bridge with the screws, but you can't win 'em all.
Old 06-12-2015, 11:10 AM   #45
dredman's Avatar
what an awesome thread
dredman is offline   Reply With Quote
Old 06-12-2015, 11:13 AM   #46
Ok.. I really need to stop thinking about this and do some work, but I can't help myself
I wonder; how do we actually properly calculate the area of the ribs?
With a solid, dimensionally simple product like a spruce 2x4 it's fairly easy. We can easily say that it is 1.5" thick and 3.5" wide.
A rib is different, though, no? It has 2 "feet" on the exterior end. Each one being 1/2"-3/4" wide, then it is ~1/8" thick metal all the way to the interior, where the surface is ~2" wide. I think the previous A.ribs was assuming a solid metal rib. Wouldn't the fact that it is hollow play a part?
Old 06-12-2015, 11:14 AM   #47
Yeh, no kidding! This is fun
It'd still be nice to get some IR thermometer read outs, though.
Old 06-12-2015, 11:44 AM   #48
Chassis: TC/2000
I need to practice making one or two of those radiation calcs. I'm gonna be taking an engineering licensure exam this October. If I can convince my boss to let me play around with some modeling software I might build a bus model.
I'll probably be able to buy enough BTUs to keep the bus hot in the winter and cool in the summer. I'm a little concerned about sealing any potential leaks. I'm sure there will be some but I'm not sure how to stop them. I was thinking of painting on something like Herculiner or the Rustoleum bed liner inside the bus. On the outside would be pretty cool, but my wife doesn't like that idea.
Tearing out the walls at this point in time would force me to repair the rusted exterior sheet metal. I don't think I'll have time to complete all of the sheet metal work before I have to have it ready in the fall. I'll probably only be able to get one or two working days a week for the next 15 or so weeks. So, in ~20 work days I'll have to have a reasonably livable bus.
Old 06-12-2015, 11:47 AM   #49
Chassis: TC/2000
I'm having fun with this. I haven't done heat transfer calcs since college. Idk how to convince my boss to let me get some modeling software though. He probably won't like that I'm using it for bus calculations.
Old 06-12-2015, 12:09 PM   #50
Engine: 190hp 5.9 Cummins
Forget what the wife wants. She has no clue about how the products work. Far too many of them base their decisions on looks alone.
Elastomeric paint needs to be applied to the exterior of the bus, not the inside.
Also forget bed liners. Not the right product for the job.
I have never understood why people allow a person with no knowledge on how things work, dictate and demand what they wants on nothing more than looks. It makes me sick. Take control and make some knowledgeable decisions.
If my wife knows more in a certain field, she can make the Educated decisions. If not, I'm making them because I know I'm more knowledgeable in most walks of life.
And yes, the metal work takes longer than building the rest of the bus.
