Old 02-14-2006, 12:04 PM   #1
vonslatt's Avatar
ATX PC Power Supply to a 12 Volt Power Source
I made a 12 volt supply out of an ATX PSU to power some stuff when "on the grid". It was pretty straight forward but there were a couple of things I had to track down like which wire to connect to get it to turn on and the fact that you need a load on the 5 volt rail to get the 12 volt rail to produce good power.
See: http://www.vonslatt.com/bus-tron.shtml
and the rest: http://www.vonslatt.com
My 1989 Thomas Saf-T-Liner
vonslatt is offline   Reply With Quote
Old 02-14-2006, 06:16 PM   #2
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Sweet! I've got a few of those power supplies laying around, methinks I might try one out!
I have been tinkering with utilizing PC & power supply cooling fans to circulate air throughout TWE. Have had some successful experiments, but nothing installed yet.
I'm also tinkering with (what I consider) unique (as I haven't seen them anywhere else yet) interior lighting options that are renewable source. (Details after more development & testing.)
Griff is offline   Reply With Quote
Old 02-15-2006, 11:22 AM   #3
Steve's Avatar
I was thinking of getting some of those solar powered yard lights, taking them apart, and seeing what could be down with them.
Old 02-15-2006, 07:57 PM   #4
Griff's Avatar
Year: 1982
Chassis: IH S1723
HEY!! QUIT PEEKIN' AT MY NOTES! That's EXACTLY what I'm doing! I have the solar panel stuck on the outside of a window, and used dollhouse wiring tape to run the wire through the window channel (avoiding slightly open windows for wires), and have the light / circuit board temp-mounted where they will ultimately go. I plan to mount them under the ceiling cabinets for passenger reading lights / area lights. So far, the results are promising.
Electric Power From Any Heat Source lornaschinske Everything Else | General Skoolie Discussions 1 03-02-2013 09:24 PM
Looking for a source for 12 volt HD compressor frank-id Classifieds | Buy, Sell, Swap 4 11-12-2008 04:15 AM
Power supply????? Battery, Generator? travlenhippie Conversion General Discussions 1 10-21-2008 11:33 PM
Power. I want more power! crazycal Conversion General Discussions 20 03-05-2007 06:23 PM
12v power selector switch source TheHokieHoopty Conversion General Discussions 7 09-04-2006 09:44 PM
