Old 08-17-2017, 11:44 AM   #1
Coachwork: Blue-Bird
Engine: 5.9
Beake Switch
The switch that is activated by the brake pedal is sticking in the on position. This causes the brake lights to stay on and the rake boost pump to run. If I activate the switch by hand it seems to function. Wonder if this switch is a know issue or maybe brake pedal needs adjustment. If I forcible pull up on the brake pedal a few times it will sometime turn off.
Also if anyone has a source to purchase this switch please let me know
David Moose
Moose is offline   Reply With Quote
Old 08-17-2017, 12:06 PM   #2
Engine: 5.9
$58.95 Midwest
David Moose
Old 08-17-2017, 03:35 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Switches are (reasonably) cheap and easy to replace.
Old 08-17-2017, 03:45 PM   #4
Reposition the switch which seems to work fine.
BlackJohn is online now   Reply With Quote
Old 08-17-2017, 04:03 PM   #5
Chassis: IH
A fairly common issue. Often the physical positioning of the switch can be adjusted to remedy the issue.
