Old 08-04-2015, 07:44 PM   #1
Chassis: Blue Bird TC2000
Engine: 5.9 Cummins 12 Valve VE pump
Best A/C for a bus?
I did a general search but only found one or two different types of A/C and heating units. Does anyone have a suggestion of a good A/C unit, with or without a heater, that covers a span up to 500sqft?
Chiller is offline   Reply With Quote
Old 08-04-2015, 09:23 PM   #2
USMCRockinRV's Avatar
Chassis: Safe-T Liner MVP
Engine: 12V Cummins
Rated Cap: 75
Best A/C for a bus?
I just did maintenance on my Mach 15
- AC is running at 49° now... [emoji15]
It stopped working this weekend - I went up it was so hot I couldn't touch it - it was clogged up with bugs and dust
Sprayed it all out cleaned my blower motor with soap and water and now it's ice box cold againClick image for larger version
Thomas
Safety Liner MVP
USMCRockinRV is offline   Reply With Quote
Old 08-05-2015, 06:32 AM   #3
Chassis: I.H.
I just looked online at that system. What gen are you using and is that a quiet system as roof tops units go? I have a Honda 3000i gen that will be under the bus.
Old 08-05-2015, 08:35 AM   #4
Engine: 12V Cummins
Rated Cap: 75
I don't know the Generation but it's 3yrs old - that Generator will do fine though
It's very quiet inside and out
It does pull a lot of amps (1 if I was to do it over I'd go with the 12.5 or 13 I forget which it is but it only pulls 9amps
Thomas
Safety Liner MVP
