Old 09-19-2019, 05:40 PM   #1
Chassis: A3RE
Engine: Cummins 8.3
Bigger roof vent?
Howdy,
I see lots of options for roof vent fans for 14" openings but mine is closer to 24"(its an escape hatch). Does anyone make a roof vent fan in this size?
Thanks,
Andy
Mtrdrms is offline   Reply With Quote
Old 09-19-2019, 05:56 PM   #2
Don't know of any 24" RV vent/fans. What most of us do is remove the hatch and replace with sheet metal, then cut the fan into the middle. I used a tinted piece of Lexan and then mounted the fan in the middle, so I have a surround of ambient coming through.
Old 09-20-2019, 08:07 PM   #3
Chassis: A3RE
Engine: Cummins 8.3
Thanks o1mark. I hadn't considered that. Would it be easier to just add another vent/fan? Is it not a good idea to put another hole in the roof?
2000 Bluebird flat nose rear engine
Old 09-20-2019, 08:48 PM   #4
are you keeping the emergency hole? Are you reskinning the inside in wood or whatnot? If the answer is yes, then make a hole that suits you. You can delete the current hole and add another or two.
Old 09-20-2019, 08:53 PM   #5
If you want to keep your hatches operational, just pick another set of ribs to put the fan between. Consider if if over a bed, or in a kitchen. Put some thought into where it would be best served.
Old 09-20-2019, 11:13 PM   #6
Coachwork: Blue-Bird
Chassis: TC RE 3408
Tomorrow I'm going to close both my emergency hatches in the roof with 16 gauge patches I've prepared. I do want a vent fan in at least one of them. But right now fans are low priority and funds are needed more in other areas.
However, I have some jigsaw blades that do a very nice job of cutting that 16 gauge if it's well lubricated, so next year I intend to cut a hole in at least one of my patches and put a fan in there. I really want 2 reversible fans, but I also want solar panels on the roof and a small deck.
So I will probably cut a new hole for the second fan, and build my own wooden hatch where the other emerg hatch was, with a ladder I can take down and put somewhere out of the way. At least that's what I'm thinking now. I will make up my mind next spring.
gs1949 is offline   Reply With Quote
Old 09-21-2019, 01:10 AM   #7
Couldn't find a day time pic.
