Old 06-28-2015, 10:49 PM   #11
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
The shelf folded. Doesn't stick out much. I Still have to figure a way to latch it in the folded position. And the hole cut out in the side just in front of the rear axle is where the Onan diesel generator goes. I have to build the slide system for that yet. Tricky as it weighs 650lbs. I'm going all electric and diesel. So if the 1k of solar falls behind i'll start the diesel genset. Water heater is electric and diesel. Heat is and diesel or the electric mach 8 heat pump on roof. The stove burner is a built in inductive unit and a convection oven/microwave.
miltruckman is offline   Reply With Quote
Old 06-28-2015, 11:03 PM   #12
Originally Posted by miltruckman View Post
The shelf folded. Doesnt stick out much. Still have to figure way out to latch it in folded position
weld the stud to a plate, mount the plate (with 4 bolts) behind the skirt, with a hole for the stud and hair pin it??? 2 small holes in tabletop
or one in center?
Old 06-28-2015, 11:05 PM   #13
Engine: 5.9 cummins
Here is the end of the cargo box installed under the bus. To the left you can see the end of the insulated stainless 110gl gray water tank. I have pad heaters stuck to the bottom of the tank with a temperature controller in case we take it out in cold weather
Old 06-28-2015, 11:07 PM   #14
Engine: 5.9 cummins
Thats a good idea. Another use for the rivnut tool��
Old 06-28-2015, 11:11 PM   #15
Engine: 5.9 cummins
Here is the platform i put on the back. It is a 12' long van ladder rack with a peice of 1/8" thick aluminum diamond plate. It ised to be on my van bit was too heavy. The bus doesn't mind the weight though.
Old 06-28-2015, 11:14 PM   #16
or a spring loaded awning foot latch with a bar mounted under the table?
Old 06-28-2015, 11:15 PM   #17
Engine: 5.9 cummins
The solar panels are on the right. I built an aluminum angle frame to tilt three panels at a time left or right. Still have to build the prop system to tilt them up. Thay are already hinged though. By the way. That array is 48" wide x 156" long.
Old 06-28-2015, 11:16 PM   #18
Engine: 5.9 cummins
That awning latch is ever. I might do that.
Old 06-28-2015, 11:21 PM   #19
even something like this mounted horizontally on outside of skirt, with recessed square hole in table flange
Old 06-28-2015, 11:24 PM   #20
or.................
