Old 04-15-2019, 02:52 PM   #1
Rovobay's Avatar
Rated Cap: 35
BLUEFIRE question.
On there site the sell several versions of the bluefire. there are a few differences but I don't know which one is right for me. I intend to buy a dedicated cheap 7 or 8inch tablet (android).
https://bluefire-llc.com/store/9-pin...j1708-adapters
The differences are "bus speed" 250k or 250k,500k and bluetooth 2.1 classic or low energy.
advise guidance appreciated.
have the day off but too tired to work on the bus so I might remove the instrument cluster and work on soldering the old connections.
Thanks
My Build: http://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 04-15-2019, 02:53 PM   #2
Rovobay's Avatar
Rated Cap: 35
The connector
Old 04-16-2019, 11:15 AM   #3
Rovobay's Avatar
Rated Cap: 35
Old 04-17-2019, 09:49 AM   #4
Mgulley82's Avatar
Chassis: 40' Saf-T-Liner MVP ER
Engine: CAT 3126 7.2L
The engine runs on what is called a “can bus” communication network.
A can bus runs on different baud rates and this connector is just letting you know it can run on multiple communication baud rates
Mgulley82 is offline   Reply With Quote
Old 04-17-2019, 10:01 AM   #5
that connector on navistar was often put in as a way for shops to program both the trans and engine..
navistar didnt start using J1939 for the main engine interface until the MaxxForce stuff in 07/08, however the 9 pin standard allows for the pins for both 1708 and 1939 to be populated.. the J1939 pins are wired to the ECM and if an electronc trans is present, the CAN 1 on it's TCM.. and the shift panel (on a 3060).. ive not tried a bluefire on the 1939 wires.. or if the bluefire 9 pin will read the J1708 wires or not..
when I plug a Nexiq into the 9 pin on a navistar, I have to select J1708 to program the engine... if I use my allison software I select the 1939.. only thing I know is to try it with the J1939 version of the bluefire..
Old 04-17-2019, 11:51 AM   #6
Rovobay's Avatar
Rated Cap: 35
Thank you.
So it does not matter if I get the 250K or the 250K/500K.... either will work correct?
I am not an apple IOS guy so I just need to figure out which of the 2 I need to buy. OR...... the IOS one has "low energy" Bluetooth vs. 2.1 classic. is that a big difference? just a few more dollars.
Old 04-17-2019, 11:57 AM   #7
Rovobay's Avatar
Rated Cap: 35
Thanks Christopher. Just need to figure out which one to buy now.
Old 04-17-2019, 12:17 PM   #8
I had the same question. Which one?
Old 04-17-2019, 10:07 PM   #9
Rovobay's Avatar
Rated Cap: 35
Yeah Steve..... which one?
Old 06-12-2019, 08:24 AM   #10
Yukon Cornelius's Avatar
Tracking
Yukon
Handyman and Shenaniganizer
http://www.skoolie.net/forums/f11/97...ion-22324.html
Yukon Cornelius is offline   Reply With Quote
Old 06-12-2019, 11:54 AM   #11
Did you ever figure out which one to buy?
Old 06-12-2019, 12:30 PM   #12
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
I had the same questions when I bought mine last year (or was it the year before? ouch, I'm getting old...). I went ahead and bought the one that works with iOS and Android even though it was $10 more than the Android-only version.
Then, when I was discussing various other things with the proprietor of BlueFire, he asked me why I bought the iOS/Android version and not the Android-only version. I told him I wanted maximum flexibility in the future because I don't know what the future holds. He seemed satisfied with that.
I relate this experience to you as I don't think it really matters which version you buy, as long as it has the connectivity you need. Since you need the 9-pin, and since the difference between the 250k and 250k/500k is only $10, I'd buy this one:
https://bluefire-llc.com/store/9-pin...ndroid-adapter
However, if you ever think you'll want iOS connectivity, then I'd buy the most expensive one:
https://bluefire-llc.com/store/500k-...08-ios-adapter
Please note that I am not affiliated with BlueFire, LLC in any way except that I bought a 6-pin j1708 adapter from them awhile back. My experience with them has been very good - I wouldn't hesitate to buy another from them.
MarkyDee is offline   Reply With Quote
Old 06-12-2019, 12:54 PM   #13
Thank you!!
Old 06-13-2019, 01:58 AM   #14
I bought mine a few weeks ago. Once I learned that I needed to turn on the J1708 protocol, it was great. The older J1708 protocol is much slower. However, many of the data points are still only accessable via J1708, such as odometer, several temperature readings, etc. When you get the unit and first start to use it, go into the "repair" screen and see what is reported. You and also get a list in the "engine status" screen. If it shows "NA" instead of a number, that data point is not provided by your bus computer.
