Old 08-26-2012, 11:18 AM   #1
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Bought a new tool
My metal chop saw went up in smoke yesterday I had thought I had seen one of these not too long ago, so I did a little research.
Cuts metal with a blade (doesn't get smaller as you use it)
No sparks
Cut is just barely warm to the touch
Makes smooth cut with very little burr
It went and bought one today and I'm impressed, it cuts 1 inch steel tubing (old seat frame) like it was butter with a hot knife. If blade life isn't an
issue (they claim 750 cuts of 2 inch square tubing) it will make cutting steel more of an enjoyable task. And the blade is resharpen able.
It is also much heavier built than my abrasive disk chop saws.
On sale 'till end of September at $100 off.
http://www.menards.com/main/tools-ha...703-c-9082.htm
If you are doing much metal work, this seems to be the ticket.
Hooking up air hose / air tool to the air break compressors? GoneCamping Conversion General Discussions 28 09-11-2017 07:14 AM
SKOOLIE - tool wishlist? BusyBus Conversion General Discussions 4 07-01-2014 02:52 PM
What is the cargo bay key tool called so I can buy one? momsawake Everything Else | General Skoolie Discussions 7 08-01-2011 08:07 PM
BEST TOOL EVER kc_4_jc Conversion General Discussions 1 02-27-2011 09:04 AM
Useful interior planning tool. oldchevybus Conversion General Discussions 2 02-22-2011 06:48 AM
