Old 10-25-2017, 06:23 PM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Broke down
Bus won't start. International rear engine dt444 i think is the starter. I had to jump start it the other day, And it worked. Now that won't even work.
Sent from my LG-LS777 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 10-25-2017, 06:24 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
If you can reach it and have some help, you may be able to give it a good sharp rap with something heavy as a friend turns the key... It has worked for me in the past.
Old 10-25-2017, 06:25 PM   #3
Coachwork: myself
Chassis: amtran
I tried, but not while someone was turning the key. I will try.
Old 10-25-2017, 06:31 PM   #4
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Sounds like batteries if jump worked ? Clean connections? You can use jumper cables to add secondary ground to chassis for quick fix.
Old 10-25-2017, 06:32 PM   #5
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
If the Bendix is starting to go, it might work.
Old 10-25-2017, 06:38 PM   #6
Coachwork: myself
Chassis: amtran
Holy ****. I worked after several tries. Thanks
Old 10-25-2017, 06:55 PM   #7
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
It won't work forever, but it might get you to a safe place to fix it!
Old 10-25-2017, 10:49 PM   #8
Coachwork: myself
Chassis: amtran
Yeah. I'm on the road stopped (walmart). I'm not shutting her down for the night until I'm somewhere safe.
