Old 04-19-2015, 06:08 PM   #1
Engine: TE 444
Rated Cap: 12
bumper question
not sure where to put this, but is the back bumper on a school bus strong enough to support a rack holding 1000 pounds bolted to it or should I bolt the brackets to teh bolts that hold bumper?
Old 04-19-2015, 07:08 PM   #2
Engine: 190hp 5.9 Cummins
In short yes, but more info would be good.
Nat
nat_ster is offline   Reply With Quote
Old 04-19-2015, 07:18 PM   #3
Bumper is 3/16 or 1/4 formed steel, limiting factor would be the bolts shearing on the frame side where it's bolted, due to vibration or impact from bouncing
If mounts can move up or down, due to loose/clearance holes for bolts or rust between mounts (crumbling out, causing loose bolts) they can shear bolts like a pair of scissors
What is application?
Mounting hardware and mounts themselves would be the limit, I think
Old 04-19-2015, 07:19 PM   #4
If you bolt anything to the bumper, the 2 feet of leverage on frame bolts is were issues would arise
Old 04-19-2015, 08:39 PM   #5
Engine: TE 444
Rated Cap: 12
want to put a motorcycle carrier on the back
also need to eventually put a trailer hitch on it
Old 04-19-2015, 09:22 PM   #6
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Ideally you would bolt anything directly to the frame with grade 8 bolts and washers.
School bus bumpers are supposedly designed to be strong enought to lift the bus. This is for if it ever needs to be towed.
So yeah, it could probably take 1000 lbs. the issue is that it was built to take impacts and vertical force. It was not designed to have a "twisting" force or pulling force like a rack would put on it.
It probably would work... The issue I think would be it sagging and twisting over time and eventually failing.
I saw a picture a while ago of someone who bolted a pintle hitch on to it without modifications. The bumper pulled out as it was not designed to take force in that direction.
Attached is the picture I'm talking about...
Hank's P-O-S is offline   Reply With Quote
Old 04-20-2015, 07:00 AM   #7
I can't even...
Did that even work ONCE?
taskswap is offline   Reply With Quote
Old 04-20-2015, 08:53 AM   #8
Lol, nice.
To bend like that the bumper mounting bolts had to have failed, or the frame rails bent together.
Nat
Old 04-20-2015, 10:04 PM   #9
Engine: TE 444
Rated Cap: 12
new plan is to get longer all thread grade 8 bolts, install them from the frame out so the bolt thread sticks out of the bumper, use the first nut to hold the bumper on then put the bracket on and use a second nut to hold the bracket so the load is transferred to the frame, not the bumper
Old 04-20-2015, 11:37 PM   #10
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I like the way they extended the bumper so the pintle would be closer to the trailer.
I'm hungry!
You Gotta Let Me Fly
Old 04-21-2015, 12:43 AM   #11
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
I can't even imagine to bolt a hitch directly to the bumper to tow or carry something. It is so much thick nice beefy steel around. It is really easy to make receiver and use it for years without thinking about loosing your goods during your trips. Just think what will happen if you drop your bike on interstate driving 60 mpg?????
Here is how another skoolie fellow solved this problem. Just scroll the page and see how. Looks good.... solid....:
http://www.skoolie.net/forums/f11/th...tml#post104205
Here is my conversion thread:
https://www.skoolie.net/forums/f11/98-bluebird-tc2000-conversion-2-feet-roof-raise-3-slideouts-9728.html
Vlad is offline   Reply With Quote
Old 04-21-2015, 08:59 AM   #12
If I was to bolt anything to heavy to the bumper, I would add a few more mounting bolts to the frame, and weld more ribs into the back of the bumper.
Not all bumpers are the same.
The 96 rear engine Blue bird only has one rear bumper.
The 2000 of the same bus has a sub bumper behind the outer bumper.
Nat
Old 04-21-2015, 07:53 PM   #13
My bad, the 2000 rear engine with a sub bumper is a Thomas, not a Blue Bird.
So many buses here I'm loosing track.
I just looked at three 2001 rear engine Blue Birds. None of them have a sub bumper.
Nat
