10-05-2019, 02:20 PM
#41
I am thinking the model would benefit by having the fuel filter/water separator in the top part of the driver side engine compartment.
10-05-2019, 02:57 PM
#42
Is it a requirement / is it common? I haven't added anything over there because many pictures I've seen don't have it (unless I'm confusing what you mean)
10-05-2019, 08:06 PM
#43
Late to the party but it looks like this!
(The fuel/water separator is the white colored metal can on the firewall. The other difference you'll see in my pic is the brake fluid reservoir since I've got hydraulic brakes.)
Please don't destroy my dog!
My bus and Native's are very similar -- my fuel tank is in the rear behind the axle between the frame rails.
I suspect I'll look fwd to driving my bus in your sim in a way I'll never drive it in real life!
Is the sim at all valuable as an instruction tool for someone who's never driven a large truck before?
10-05-2019, 08:43 PM
#44
Originally Posted by banman
snip
Cute dog!
Potentially. They did a video on how the physics compare with reality here:
https://youtu.be/FPX2qRQAnBo
Out of curiosity what's the capacity of it? The one on my model is ~70gal (It was originally 60 but it was resized and I never re measured).
10-05-2019, 09:53 PM
#45
SNIP...
Fuel tank is 100 gal.
10-06-2019, 01:29 AM
#46
Ours is 65 gallons. So you can see that not all buses are built exactly the same, even if they are the same body style.
The water separator in the photos I provided iabove s the red cylinder with the clear bottom ... located towards the outside of the bus from the compressed air manifold. Banman's separator does not have a clear bottom, but functions the same. It takes the water and heavy debris out of the fuel before it goes into the fuel filters.
10-06-2019, 01:56 AM
#47
Yup. I based mine off of some info I found around here saying that some states require a min 60 gallon tank, so I just went with the bare minimum.
BeamNG has a customization menu so maybe I could add back/left/right tanks all in various sizes as options, as it would affect the actual vehicle performance and weight too
10-06-2019, 02:40 AM
#48
Yes, the size and location of the fuel will affect the handling of the vehicle to some degree.
Any chance the model can have the option of raising the roof or adding cabinets or insulation so we can test out all our designs? (just kidding, sort of)
10-06-2019, 02:47 AM
#49
Heh, a converted variant might actually be a fun idea ;)
10-06-2019, 09:21 AM
#50
It wants to be clear...
Definitely needed cleaning...
10-06-2019, 09:36 PM
#51
To be honest, mine needs a cleaning too ... and it is a yellow color. Yours looks to be a deeper shade of amber. In the forst picture though, it looked brown! So, your separator bowl is now way cleaner than mine!
10-07-2019, 09:34 PM
#52
(nevermind, asked something based on an incorrect assumption)
10-08-2019, 12:46 AM
#53
I thought you might be avoiding us!
10-08-2019, 12:54 AM
#54
Just a bit burned out from modeling stuff. I've only got a small todo list left (e.g. interior mirror) but the final steps are always the hardest
10-08-2019, 12:59 AM
#55
Looking good! Do you need pictures of the mirror? Just today, I added extension bars to get mine up higher. I have a tall sitting height.
10-08-2019, 01:19 AM
#56
The more references the better ;)
10-08-2019, 02:44 AM
#57
Here is an old photo I happen to have right now. It shows the mirror mounting bracket and the shade. The mirror was not installed at the time of the photograph. I will have to take a photo as it is right now and post it in a bit.
10-08-2019, 03:02 AM
#58
Here is the bulkhead WITH the mirror installed.
10-08-2019, 08:52 PM
#59
Awesome. Those pictures + a part listing brochure for sizing and attachment meant I could complete this area
EDIT: oh, what's with the shape of the roof by the way? Just a styling choice?
10-09-2019, 03:33 AM
#60
It does look good! Nice job. You are quick at making the changes.
The shape of the roof is for roll survivability ... no sharp edges to catch.
