Old 05-31-2017, 08:40 PM   #61
What would the interior height be?
I am looking at an auction for a 1996 International/Thomas mini Bus
Any idea what the interior ceiling height would be?
I am 6'1" and would rather standing room.
ozsager is offline   Reply With Quote
Old 07-21-2017, 07:17 AM   #62
Coachwork: Chevy Midbus
Engine: GM 6.5 Turbo Diesel
Intetior height on International/Thomas short bus
Does someone know the interior ceiling height for this 98 International/Thomas 3600 bus is by chance?
Thank you!
jordan76 is offline   Reply With Quote
Old 07-21-2017, 01:28 PM   #63
IDK bout the height, but they ride pretty rough.
Old 10-24-2017, 06:18 PM   #64
school bus vs transit
so 2.5 per window for a school bus makes sense is there a simple formula for transit buses? I'm trying to figure out with a family of 5 which would have more room.
iahawkbus is offline   Reply With Quote
Old 10-24-2017, 06:36 PM   #65
Chassis: Saf-T-Liner MVP ER
At least for Blue Bird, you can find out the exact length for anything newer than about '94ish. Before that records are sketchy.
Just enter the VIN # here:
Unit Dashboard | Portal...
The four-figure number under "Length" is, I believe, feet and inches.
Later they changed the code to "6600" or "7700" and I haven't decoded that yet.
BB also have a chart for decoding the VIN #. That gives the length too. Take off maybe 3' for transit and 5' for conventional and you roughly have the distance from the back of the driver area to the rear of the bus.
Steve Bracken
Build Thread
Old 10-24-2017, 06:57 PM   #66
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Thank you!
VIN decoder Gates VIN Decoder
Old 10-24-2017, 07:04 PM   #67
what would give me more room school bus or transit?
Old 10-24-2017, 07:06 PM   #68
Either.
They both come with low and high ceiling variants.
Steve Bracken
Build Thread
Old 10-24-2017, 07:54 PM   #69
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
I've a transit-style school bus. 78" interior height.
Old 10-24-2017, 08:26 PM   #70
I don't think that site ever provides interior height or other dimensions, better for engine info.
Sent from my SM-G920T using Tapatalk
Old 10-24-2017, 08:59 PM   #71
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Ir DOES provide interior height.
Old 10-24-2017, 10:01 PM   #72
It provides bus length for most Blue Birds, because it is coded into the VIN #
Steve Bracken
Build Thread
Old 10-24-2017, 10:23 PM   #73
Good point on the length. Is there a way to determine interior height from the VIN though? That's what i was looking for when I had initially posted, would be awesome if there was but I haven't found a way yet.
Old 10-24-2017, 10:45 PM   #74
Not for Blue Birds, but the BB site sometimes lists it. VIN # codes interior height in Thomas Built.
Steve Bracken
Build Thread
Old 01-17-2018, 11:31 PM   #75
Any buses under 30' feet that are 78" inches tall?
I'm looking for a bus under 30' with at least 20' of usable space that is 78" tall. Does this exist? My husband is 6'4.5" so it's a must and we don't want to have to raise the roof.
Thanks!
Marisa
Marisa is offline   Reply With Quote
Old 01-17-2018, 11:55 PM   #76
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Rated Cap: 16
Thanks!
Marisa
This does exist. Our bus is 30ft bumper to bumper, and our ceiling is 78inches tall. We have a 9 window carpenter on a 1998 International 3800 chassis with a DT466e and, as of tomorrow, will have a MT643 transmission... We both can jump inside the bus and not hit our heads...it's wonderful. Granted, we are both under 5'10"....
John & Beeks
Sent from my SM-G950U using Tapatalk
johnbloem1974 is offline   Reply With Quote
Old 01-18-2018, 12:07 AM   #77
John & Beeks
Amazing! Thank you so much John & Beeks! How wide and long is the usable space inside? Also, why the new transmission, should I be aware of something with it? Anything else I should know about this bus?
Thank you!
Old 01-18-2018, 12:10 AM   #78
Rated Cap: 16
Inside useable space is about 7'5" wide. Our AT545 transmission crapped out after 2 years of mountain driving and towing....
Old 01-18-2018, 12:12 AM   #79
Rated Cap: 16
If you can, avoid the AT545 if you will do any extensive interstate driving. It just isn't designed for it...
Old 01-18-2018, 12:22 AM   #80
thanks! How about the length from behind driver to the back of the bus?
Capacity and Bus Dimensions Seeria Conversion General Discussions 7 08-29-2017 05:22 PM
Bus interior dimensions? SweetBearCub Conversion General Discussions 5 09-04-2013 05:59 PM
Interior Dimensions Seeria Conversion General Discussions 5 11-04-2009 07:43 PM
Dimensions question Redbear Conversion General Discussions 2 10-19-2009 07:39 PM
Dimensions Rose Conversion General Discussions 1 03-10-2004 10:09 AM
