Old 10-26-2006, 11:30 PM   #1
oldog12's Avatar
Bus Height
How high should I plan for a garage door to fit a Blue Bird FE?
oldog12 is offline   Reply With Quote
Old 10-27-2006, 10:11 AM   #2
This is going to sound obvious; measure the bus height. Use a ladder, a tape measure and a level, standing next to the bus; then when the level is equal to the height of the bus, measure from the level to the ground, and presto, the height.
Or the funny way is to try driving it through progressively lower doorways or under bridges until it hangs up; then make the garage door a bit taller.
This is a variation of finding out a bridge's capacity for the warning signs; keep running heavier trucks onto it until it collapses, then rebuild it and put the sign on.
DO NOT bother taking advice on how tall your bus SHOULD be. With the additions and changes you're going to make, it will change. So measure the bus, it's the only safe way.
Ryan Grimm is offline   Reply With Quote
Old 10-27-2006, 01:05 PM   #3
eggman's Avatar
Just a bit to add to Ryan's info.......measure at the back of the bus. If yours is anything like mine is, the back of the bus is taller than the front. And include the vents and the strobe light.
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 10-27-2006, 05:51 PM   #4
Coachwork: Ward Genesis
Engine: DT466/MT643
Ballpark--most FC Birds I see are 10'6"-11' tall. Conventionals are usually about 10'6". Definitely measure, though--also, I'd add AT LEAST a foot higher than the actual bus to allow for things like A/C units, vents, & such.
Jarlaxle
Old 10-31-2006, 12:07 AM   #5
oldog12's Avatar
Well fellas... I guess I was putting the cart in front of the horse....
I'm looking forward to getting a Blue Bird FE in the future to convert, and was wondering about how high I should plan for a garage door, since we're planning on putting up a new pole barn here...
BTW Thanks Jarlaxle for the info...
Old 11-02-2006, 08:29 AM   #6
In that case, plan on a door taller than you think you'll need; it becomes a feature when you sell the place someday.
And a taller-than-needed door will always work, regardless of how tall the bus is after mods, etc.
I'd LOVE to have a tall-doored garage/barn. Can't build one here, due to lack of space.
Old 11-02-2006, 06:27 PM   #7
Engine: DT466/MT643
The 1998 TC1000 I drove was 10'2" tall, not counting the roof-mount antenna. It was a 25-passenger w/c bus, with a flat floor & 265/70R19.5 tires. It was actually a nice bus...but beware of the kooky gauge cluster.
Jarlaxle
Anyone Know of a Bus 13 Feet or More in Height ?? lornaschinske Conversion General Discussions 5 08-16-2012 11:27 AM
Floor height pullinbus Conversion Tutorials and How-to's 5 05-28-2010 09:58 AM
Ceiling Height oldog12 Conversion General Discussions 3 12-31-2009 11:07 PM
What is the interior height of your bus? nearhomeless Conversion General Discussions 6 05-28-2009 09:00 PM
Height restrictions Jeff in AK Everything Else | General Skoolie Discussions 7 03-12-2005 03:35 PM
