Old 08-29-2015, 10:05 PM   #1
Engine: TE 444
Rated Cap: 12
bus number 2 is "home"
the second Bus I bought is home, in a storage lot
new bus is a 2000 IH bluebird, 25 feet long, flat floor, AIR CONDITIONING woo hoo!! cruise control that works, TE 444 hydraulic brakes and the dreaded at545
A bus door with a built in lock, never heard of this before, and it works
Old 08-29-2015, 10:21 PM   #2
We have the same lock. Looking good!
Don and Mary
dond is offline   Reply With Quote
Old 08-30-2015, 10:08 AM   #3
Great looking unit. What are your plans for this darlin'?
Old 08-30-2015, 10:37 AM   #4
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Is it on one of thoes "low-pro" chassis?
The tires look small.
Hank's P-O-S is offline   Reply With Quote
Old 08-30-2015, 11:04 AM   #5
Engine: TE 444
Rated Cap: 12
I think it is, tires are 19.5 inch, plans are minimum required stuff to title as motor home, cover some windows and use it for camping with motorcycles
Old 08-30-2015, 10:27 PM   #6
Looks like you could go up in tire size. If the engine has the grunt to pull them, it would add a fair amount to your top end and cut fuel usage too.
Old 08-30-2015, 10:44 PM   #7
Engine: GMC
Rated Cap: 42
Tango
How does this work? Going from 19.5 to 22 tires lowers the engine RPMs and therefor cuts fuel usage? Do I have that right or is there another reason?
JA Savage is offline   Reply With Quote
Old 08-30-2015, 11:20 PM   #8
Engine: TE 444
Rated Cap: 12
it has a 3.90 rear end, governed at 64 right now and will hold that pulling a small car, but I doubt it has the torque to handle bigger tires with that rear end, 190 hp te444, AT545. the combination seems to work good in this bus, will know when i go somewhere in it not towing the car behind it.
also since it is a flat floor bus, there is not much clearance over the rear tires to the floor
Old 08-30-2015, 11:45 PM   #9
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Sounds like a nice package.
Old 08-30-2015, 11:57 PM   #10
At the same engine rpm's the larger tires cover more ground. But, that said, some folks do go bigger so they can turn fewer rpm's at the same speed they used to run. But as noted, if you opt for more speed, the engine has to have enough torque to turn the tires faster. Likewise for gearing taller.
