Old 09-19-2017, 12:39 PM   #1
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Bus Specs Sheet- generic maint guide
Saw this idea elsewhere, thought it'd be handy in 1 spot. Fill it out and post to your build page for your own reference/sanity. Also nice if you loan your rig out.
Sure I forgot lots a bits- feel free to improve.
Part Numbers
Year Make Model
Factory Phone Number (timezone,city):
Service: 800-
Sales: 800-
Parts Sales: 800-
Chassis No:
Body No:
Service No:
GVWR:
Dimensions: Height/Length/Width
Engine:
Serial No:
Injection pump/Carb: Make,model
Turbo: make/model
Starter Motor: make,model
Compressor/Vacuum Booster: make,model
Alternator: make,model,amps
Belt 1:
Belt 2:
Battery: (quant) make/model/CCA date
Radiator: make/model
Coolant: capacity/flavor/date/additive
Radiator Fan Clutch: make, model
Water Pump:
Radiator Hose, upper: to rad: to eng: size/adapter
Radiator Hose, lower:
Radiator cap: lbs
Air Filter:
Oil Filter - prefer: , else:
Oil drain bolt: size
Engine Oil: weight, capacity
Fuel Filter/Separator 1: #, location
Fuel Filter 2:
Genny oil:
Genny filter:
Transmission: Auto, make model,serial
Trans Capacity: type fluid, qts SCA
Power Steering Pump:
PS Fluid:
Drive Line Series:
Universal Joints: Spicer
Midship Bearings: Spicer
Blinker Fluid: capacity
Air Dryer: Make/model/desiccant cartridge date
Front Axle No:
Front Axle: make,model
Front Axle Capacity
Front Brake Lining Kit:
Drum specs front: #,min thickness
Rear Axle No:
Rear Axle Ratio: make,model
Rear Axle Capacity
Rear Lube: capacity/weight
Rear Brake Lining Kit:
Drum specs rear: #,min thickness
Tires-Steer: size, manf, date
Tire Pressure,steer:
Tires-Drive: size, manf, date
Tire Pressure, drive:
Lug torque: ft/lbs
Headlight bulb:
Fr turn bulb:
Rear turn bulb:
Brake Bulb:
Clearance Marker bulb:
Windshield wiper: length
Old 09-19-2017, 07:38 PM   #2
Chassis: Blue Bird
Engine: ISC 8.3
The blinker fluid is especially good to make note of! Like engine oils, blinker fluid comes in several weights. The problem is that no manufacturer publishes the weight requirement for their blinker system. One has to draw some of the fluid out of the reservoir and test it by the Turing test method to find out the correct weight before the reservoir runs out.
Old 09-21-2017, 02:17 PM   #3
This is an awesome idea. I'll have to try to fill this out as we get to know our bus a little more. We'll be full timing, eventually, so being able to open a folder and pull out a comprehensive spec sheet like this will be really handy when roadside emergencies arise!
Old 09-21-2017, 02:26 PM   #4
Traveling
Rated Cap: '00
When you are under the hood and see a manf sticker/label- snap a phone photo. It's a bit of work up-front, but saves time in the end.
Autoparts store didn't find a radiator hose for a BlueBird bus, but could get me a Gates 2060 because I copied the markings on the old hose.
Old 09-21-2017, 03:14 PM   #5
Funny you should mention Gates. I'm doing a VIN lookup and copying all relevant information (from Gates and also Dayco) into a spreadsheet as we speak. It was a quick copy/paste from your post to an Excel. The guy who's doing the demo and painting on the bus has given me the filter numbers, so I've filled that info in too, and I've used pics of the ID stickers on the bus, tires, and batteries to get some of that info. I'm about 1/4 complete on the sheet, and I've only been working for 30 minutes.
I'd much rather do the work upfront than try to do it on the side of the road in the middle of nowhere.
spec sheet maintanace
