Buses with built in AC...
I've read a lot of the build threads on this forum, and I don't think I have seen any buses converted that came with the factory AC. Is this because the AC takes up to much interior room? Not reliable? or is it just because that AC cannot be used when camping?
What do you folks do for cooling when you are on the road? I live in Miami so cooling is slightly more important to me than heating! We are planning on using the bus as a tin tent for camping to start with and then build it out as our needs change.
One of my thoughts was to convert one of these buses with the dual ACs, remove one of the units and replace it with a mini split unit that runs on 120ac, housing the external compressor in the space where the factory AC was. Is this feasible or do I need to put down the pipe and come back to reality?
Thanks!
