Sorry to ask but I've only just started researching buying a bus, have learned a lot in a few days but am sure I don't know everything in order to make an informed decision. I wouldn't be in such a rush if the IDEAL bus hadn't just showed up for sale. So, I'm looking for tips on what to check out (and yes, I did read the 'So you wanna buy a bus?' thread! Again, I'm sorry)
Just found a '92 Bluebird 84 pax with Cummins, auto, air, storage boxes, etc = everything I'm looking for and it's the right side of the border (Canada
). Seller is offering to pay for any repairs needed on agreed sale and commercial licensing fees.
I asked for more info on auto, service history, rust, tires, and what repairs are required. Got this reply:
"No history but it was used to train school bus drivers for over 10 years. Bus was built to carry 12000 lbs of kids. It has had to be certified every 6 months as a school bus and they are very strict about school buses. This one has been babied! Last time it was certified was Oct 2016 and has been sitting ever since. The speedometer was replaced and it shows 550,000 kilo. Previous owner said 190,000 miles on the bus. The Cummins is a Million mile motor. Cast iron block and head with mechanical injectors said to go the distance as is this motor. Last test run about three weeks ago, the bus performed excelently.
Tires will pass the certification for commercial use.
Minor rust on a cross member but that is a minor fix.
The mechanic that did the inspection and estimate for full certification for commercial use said less than $1000 to repair what is wrong; fuses, light bulbs, minor electrical connections in fuse panel (corrosion from sitting), condensation in the differential (from sitting), exposed metal on cross member showing rust"
Anything red flags there? Anything else crucial I should be considering/asking? Too far away to take a quick look and I'll prob get an independent mechanic to look it over in any case.
Cheers
