Old 03-16-2007, 09:05 PM   #1
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Can I fix this without taking it apart?
This is the right rear corner of the bus. Is there a way to fix this. The soot from the exhaust is coming through the hole and is getting on the walls and ceiling. I don't really want to remove and replace all those rivets. Suggestions please.
I'm hungry!
You Gotta Let Me Fly
Old 03-16-2007, 09:33 PM   #2
Steve's Avatar
Duct tape! You could maybe use a dent puller on it but it looks pretty stiff. Maybe take the inside panel off and pound it back off, at least you can still drive it around with the inside panel off.
Old 03-16-2007, 10:05 PM   #3
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Maybe you could first use a block and mini-maul or a hydraulic ram to straighten out the interior skin while it's still attached, then remove the inner skin and push out the exterior skin. That way the interior skin might line up a little better when reinstalling it. (But I guess that requires taking it apart, DOH! . . . sorry)
Griff is offline   Reply With Quote
Old 03-17-2007, 09:25 AM   #4
How good are you at drilling out rivets? Looks like that inside panel is coming off. You could try using a body panel puller from the outside, but, then you got a bunch of holes to patch. Take off that inside panel and get to whacking. Have someone hold a decent sized piece of 2 by something or other on the outside. This will hopefully keep it from bulging outward.
pete c is offline   Reply With Quote
Old 03-17-2007, 06:36 PM   #5
lapeer20m's Avatar
if you just want to stop the exhaust from entering you could use silicone. It won't help with the dent though.
Old 03-17-2007, 08:13 PM   #6
oldog12's Avatar
... Wasn't it Les that said he punched out the center pin in the rivet with a thin punch and the rivets practically came out by themselves ?
... Than inside panel doesn't look bad at all, you'll just have to get the outside one "Just good enough"
oldog12 is offline   Reply With Quote
Old 03-17-2007, 11:25 PM   #7
Moderator
crazycal's Avatar
I think taking the inside panel off and trying to straighten the outside panel in place is a good idea. I dread the thought of drilling and repalcing all those rivets.
I'm hungry!
Old 03-18-2007, 12:12 AM   #8
oldog12's Avatar
... Well, I counted 48 of them in your picture.... So maybe 64....
Try getting a thin punch and see if you can knock out those center pins on a couple of them.
Its supposed to be easier than drilling them out.
Worth a shot... If it works, let me know
Old 03-18-2007, 09:58 AM   #9
eggman's Avatar
What about getting a large steel bar or tube, somewhere in the neighborhood of 2 x4 or 4x6, add a large c-clamp. Remove the hinged door/window, using the bar/tube and the c-clamp try to get the dent to come back out. I would think that it would be worth a try. Otherwise, you'll have to get busy punching and drilling.
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 03-19-2007, 08:52 AM   #10
Les Lampman's Avatar
Not me this time.
I wouldn't know what to do with this either except to figure out a way to get the inner panel off so the exterior skin could be hammered out from the inside.
Knowing me and body work I'd be heading down to the Community College and asking their body shop classes to have a go at it; there's no way they could do a worse job than me!
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 03-19-2007, 01:31 PM   #11
the_experience03's Avatar
How about a gallon of bondo or a rerouted exhaust?
Old 03-24-2007, 05:22 PM   #12
Elliot Naess's Avatar
Engine: 5,9 Cummins
Hard to say from pictures, but...
Millicent had a nasty dent in the roof, just above the windows, where they had sideswiped
a telephone pole. The structure was bent a couple of inches inward, as it seems to be with
that door frame.
I was surprised how well it went:
It took a hydraulic bottle jack and timbers. The hard part was rigging the timbers so I could
push on the damage. Once the wood was in place, the Brute Force pretty much reversed the
other brute force.
Perhaps you can push against the wheel wells?
Old 03-27-2007, 09:00 PM   #13
Moderator
crazycal's Avatar
Maybe I could have used my new porta-power if some puke didn't steal it after I used it one time. I started drilling rivets on the inside instead. I'll give that a shot. I knocked out the center, then drilled the rivet.
I'm hungry!
Old 03-27-2007, 10:53 PM   #14
Engine: 5,9 Cummins
I don't know what a porta-power is, but hydraulic bottle jacks are surprisingly
affordable. And four-by-fours (the lumber kind) are everywhere.
Old 03-27-2007, 11:13 PM   #15
Moderator
crazycal's Avatar
A porta-power comes in a case that has a pump with a hose that you attach to a ram. There are extensions and other attachments that help to fit your specific task. I bought it to straighten an axle and it worked like a charm. They come in very handy. But I don't think it would have worked very good for this dent. Here is a link.
http://www.harborfreight.com/cpi/ctaf/D ... mber=44900
I'm hungry!
Old 03-27-2007, 11:42 PM   #16
Engine: 5,9 Cummins
Ah yes, a bit like George Hurst's rescue tool -- now generically known as Jaws Of Life.
How long to Christmas?
Taking over a Project - No name for the bus yet. Stuff Skoolie Conversion Projects 2 08-10-2011 09:25 AM
Taking the bus on a trip to Montreal and Nova Scotia Crisco On the Road | Travel, Trips, Camp Sites, Tailgates 1 06-17-2011 05:52 PM
Reason For Taking Off Lights ? shortstuff Skoolie Conversion Projects 3 08-31-2009 12:27 PM
Journalist looking for people taking to the road reporter1 Everything Else | General Skoolie Discussions 0 02-04-2005 11:42 AM
Band taking the bus route calledisrael Everything Else | General Skoolie Discussions 0 06-15-2004 12:44 AM
