Old 12-10-2014, 09:29 AM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Carpenter noises
When I put the key in the "ignition" of my bus, all sorts of electrical whining and motors start up. I can't fathom it as all my switches are off and nothing should be happening. Any ideas?
Zephod_beeblebrox2 is offline   Reply With Quote
Old 12-10-2014, 03:09 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Carpenter noises
If you have air brakes it's probably low air warnings, they are supposed to be loud and annoying.
Old 12-10-2014, 08:51 PM   #3
Year: 1994
Engine: 466dt
Rated Cap: 59
No. I don't have air brakes. It's more of a mechanical chugging as if there's some electric motor doing something. No idea what it could be unless its an electric fuel injector.
Old 12-11-2014, 06:04 AM   #4
Does is go away once its running?
Mine had a few different buzzers but I've already disconnected two.
Could be the hydraulic booster?? Or a brake warning of some sort...
There are a ton of noisy things in buses you just have to eliminate things one at a time till you're happy.
Best of luck!
Roll Your Own Build Thread
Old 12-12-2014, 09:10 PM   #5
If you do not have air brakes, there may be an electric vacuum pump for safety to provide back-up vacuum to the power brake booster.
Old 12-12-2014, 09:38 PM   #6
Year: 1994
Engine: 466dt
Rated Cap: 59
I'll try to do a video tomorrow. I'm visiting my bus for the weekend (its parked on my girlfriends land). I'm going to be spending a while painting the roof and popping rivets into screwholes some idiot drilled in the roof for an awning that had fallen apart. As the rivets will be under no stress due to them being through a hole in a single layer of metal, I'll use ordinary pop rivets and epoxy glue to seal them.
Old 12-13-2014, 12:30 PM   #7
Year: 1994
Engine: 466dt
Rated Cap: 59
odd noises. 2.3mb video
Odd motors: http://youtu.be/SgnaWZoTs68
Old 12-13-2014, 01:28 PM   #8
Either the lithium thrusters are cycling or the gauges are
Don and Mary
dond is offline   Reply With Quote
87 Ford/Carpenter Bus Makin Me Hot? Huskie1 Mechanical and Drivetrains 2 06-23-2014 08:53 AM
Twin Bus - '91 Carpenter w/ 7.3L International Diesel Dan Short-Bus Conversion Projects 14 03-12-2013 05:33 AM
95 Carpenter Questions Versatile Conversion General Discussions 1 12-21-2011 10:00 AM
1983 carpenter body mamayogibear Classifieds | Buy, Sell, Swap 0 06-10-2011 01:02 AM
What it this button for? (and some weird noises) gbstewart Conversion General Discussions 8 03-17-2011 12:59 PM
